I think I've mentioned this before but my tuner who Tuned f-con on my car.
He can make the harnesses.. For a price. But its An option there for you.
And Theo my tuner has a map that adjusts the shifts I sent it to Scotty too. It changes hard and fast and can go harder and I've got 725cc injectors
Edited by Footo
Oh yeah rs6 daaahhh sorry :)
Well that's a whole lot more awesomeness. Is that the same engine as gallardo and r8 but with turbos?
Hey footo, gearbox map sounds the goods, I think I remember reading that your tuner could make a harness up, but didn't he want like $800 or something crazy like that?
Does anyone here have one set up without the original vq25 harness? Did your tuner make yours when he installed the fcon or did you have it already?
Yea I think he may of lowered his price If he could get 2 or 3 made.
He also mentioned he saw one being bought by Jesse streeter a few months back, I'm sure he could find another for you.
Mine is a original which he already had.
He spent alot of time On setting it up and tuning(on-road)
Yeah I was thinking of asking Streeter to have a look for me, but he normally has a break over Christmas so maybe I'll try in the new year.
What you reckon I'd have to pay if you can get one Craig?
just keep an eye on import monster, thats how i got mine was only 280nzd all up
For the harness, not the Fcon. V3.24 or 3.3 you will need I think.
Cool, cheers!
The turbo arrived today :)
It'll take me forever to get all the stuff I need to make everything work...but I'm pretty excited!
Haltech have just announced a new ecu (elite) with electric throttle control (with cruise control), and 4 indipendant cam control. How does the m35 auto ecu work? Does it use CAN or just analogue signals?
It uses CAN, but not the same CAN setup as the VQ35 afaik. It can run independently to some extent, with no kick down.
I am starting to think a VQ35 transplant is on the cards along with the 6 spd manual conversion. That new Haltech would be very nice to get working.
  • 11 months later...
They can't even get the VQ30det running right, no electronic throttle, no EVCT. It's always so easy until you realise it actually isn't.
Sorry to pic your brain, but what do you know the who/when on VQ30DET testing/wiring?
My 2003 y34 vq30det has cable throttle but not sure on the VCT side of things.
From what i can gather the ECU pinout is the same as the NM35, so think im in the same boat. When i get a chance ill try to hunt down to see if theres a separate ecu for the CVT gearbox.
Note: most cars with Vq30det conversions are running y33 motors which have different ecu pinouts. Not sure on what other stuff the motor does or doesnt have
tranny ecu will be in the passenger kick panel. Engine ecu is above that behind the glove box
  • 8 months later...
thread dig again... any body sussed out this 350Z ECU?
http://www.syvecs.co.uk/products/engine-management-system/s350z/
doesnt tell you a whole lot, but from what it does say it could same ECU plug.
im guessing its similar to the Vipec option http://www.vi-pec.com/ecus/iseries__pluginecu#nissan
but says VQ35DE applicable only. but also says capable of doing forced induction....
Here's a bit more detail from the factory site;
http://www.linkecu.com/N350Plus
It has a slight possibility it might be compatible in some way with the series 2 m35, but i would 99.9% confidently say it would be a whole world of issues with the vq25det and just won't work.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
