My 1988 Nissan Cefiro has recently failed a WOF on the park, tail and license plate lamps not illuminating with the headlights. Hasn't been working for a few weeks but haven't gotten around to looking into it. Figured it could be the headlight switch on the steering column but testing it seems to show that's not the problem. I've looked at and replaced the blown fuses on the interior fuse block and that's not the problem. I've looked at and tested the tail light relay in the engine bay and thats' not the problem. I have looked into the auto light relay unit in behind the right headlight, and have found slight corrosion on one of the relay power pins, however I don't know if thats the right issue. I'm pretty stumped, and it's probably going to come down to a shorted wire somewhere in the circuit... What do you guys reckon?
https://www.sau.com.au/forums/topic/435800-a31-faulty-headlight-circuits/
I've had this problem more than once and it was the switch, to test it, unplug the stalk and bridge the two wires together responsible for the running light circuit, I can't remember off the top of my head which wires but I will check tomorrow.
It's probably a smarter idea to bridge them via a fuse and see what happens, but if there is a short circuit and you bridge it with a little piece of wire you'll know about it pretty quickly (it will get HOT), but then again your fuse should have popped if that's the case already.
It could be an incomplete ground anywhere on the circuit, which was my problem the first time (front left parker globe holder), so check your parkers first, it's very unlikely to be a ground in the interior.
The headlight circuit will run fine without that brown box plugged in, so don't worry about that.
I'm using an S13 switch at the moment while I source a working A31 switch, the running lights only come on when the headlights are on (second click), they don't come on with the first click, not sure if that's because if a different design to the A31 stalk or what, but an S13 stalk should get you out of trouble in the meantime.
Sounds like a plan. While I had the stalk out, I used a screwdriver to bridge the center contact with the contacts on either side of it and the system worked fine, so my assumption was the switch worked fine but there was something further along in the circuit that wasn't bridging it properly.
EDIT* Although now that you mention things popping... I had my left hand headlight die around, if not at the same time, as my running lights failing... but my headlight fuses are perfectly fine. Possibly a bad earth around the headlights?
Edited by promaori
my left headlight globe went a few months before I had some drama's as well, so yeah something sketchy in the design in that front left corner I think...although headlights are on a completely different circuit so they should be unaffected
    • Yeah they charge a little extra for mods , last year I noted no mods but I did have an exhaust fitted after that so  better to let them know cause these kinds of things can cause the policy to be void if you ever need to claim.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
