For sale: 1991 R32 Skyline GTS-T 4 door
Price and price conditions: $7500
Condition: good for its age, usual wear and tear,
front RH guard is slightly rippled, no RWC, but passed with flying colours 1 year ago
Contact Details: PM to discuss
Basic Details:
RB20DET, manual, 180rwkw, motor and box both rebuilt by previous owner (no receipts sorry). Car's got all the fruit to make more power if you put a bigger turbo on. Ready to drift if you put a halfcage in.
I love this car, but it's just too expensive to try to rego/insure/maintain 3 cars. As you can see below I've replaced a stack of items within the past year, overall its a great car. One bad thing, climate control works perfectly except for the screen.
Full Mods List:
Items in green replaced within last year
RB25 turbo, braided water lines
Z32 AFM
Nistune Ecu tuned by Racepace
GTR injectors with genuine nissan injector seals
Turnflow FMIC, black core, black piping, looks legal as
Exedy Copper Fibre Clutch, very streetable, installed 3months ago
Standard BOV rebuilt to hold more boost without leaking
Walbro fuel pump
Catch Can with fibreglass heatshield sleeving on the hoses
Boost tee, running 11psi
3inch exhaust w/ Varex muffler
3inch dump pipe
Small oil cooler, hidden behind side of front bar
GKTECH braided clutch line, master & slave replaced
Slotted Rotors, Project Mu pads up front, unknown rear pads
Cusco MZ 2way diff
Driftworks coilovers, 8/6kg springs
GTR rear swaybar
Momo dished steering wheel
ADR approved race seat on driftworks superlow rail
Adjustable front camber arms
Cusco caster rods
Hardrace swaybar links up front
Pioneer headunit , sony rear speakers, ipod connector
Turbosmart eboost (solenoid broken, so use it as a boost gauge, replacement solenoids are ~$150 IIRC)
Digital water temp gauge
Aircon regassed + new drier etc
GKTECH clutch fan
R33 GTST stock wheels with Toyo R1R front tyres, heaps of tread, bridgestone rear tyres on wear indicators
New tierods ends (to pass RWC a year ago)
Rack spacers
Horn rewired + new relay
Indicator relay replaced
Fire Extinguisher
Nismo copy floor mats
Comes with the following spares:
R32 gtst stock wheels in poor condition, need repaint
Headlights
Bonnet Latch
Std caster rods
HID headlight kit
Front guard
Std drivers seat
Std steering wheel
Pictures:
AVS & Enkei wheels not included
https://www.sau.com.au/forums/topic/435805-vic-4door-r32-skyline/
  • 4 weeks later...
Full interior pics please.
Still running that 3.5" (looks about that size?) muffler?
Also, the pictures you posted provided by the previous owner; is it safe to say the car is in similar condition minus the rims? Can you take more recent pics anyway? Takes 2 mins with most modern mobiles these days ~
Either post here or email to [removed by admin]
Very keen assuming you're willing to negotiate. I'm looking for a GTS or GTS-T daily/toy/project all in 1. This seems to fit the bill perfectly.
Will this pass RWC? If not, what work needs doing for it to pass?
Cheers
Edited by Revhead
yeah same muffler, looks about 3.5inch yeah, its a varex
car is in exact same condition as photos, hasn't deteriorated more since I bought it, looked after well
1421104_10152061552650682_102203117_o.jp
Cheers
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
