hey guys had a bit of a search but couldn't find my answer.
ive installed a plazmaman throttle body and plenum
I hooked a compressor up to my intake to pressure test the system whilst doing so found that it was leaking around my tps.
I removed it and sure enough there was a fair amount of air coming out from the end of the throttle shaft seal. it starts to leak at about 14psi and gets worse up to 22psi where I stopped as that's around where itll be getting tuned at.
just want to check if this is normal.
I called plazmaman and they told me that its completely normal and it wont be noticed also that I shouldn't have been doing this as its a static pressure 20psi and so on.
any input from experience would be much appreciated
It shouldn't do that. I can accept that no seal is perfect and that there might be a small leak, but if it is a lot of air, then that it wrong. Having said that, what you think is a lot of air and what I think is a lot of air are likely to be quite different.
In addition, kick the Plazmaman phone person in the snatch for being stupid. There is no difference between being put under 20psi internal pressure on a purely static basis and having the air flow past. Knobheads!
lol well it does seem like quite a bit of air to me but who knows, I guess when it goes in for a tune up ill see what unigroup think.. I didn't think there should be a difference with the static vs dynamic thing but didn't want to seem like a knob head arguing the point if I was wrong
haha I gave the fitting I used to hook up the compressor back to its owner.. on my hand it felt like the amount you would expect to come out of a 1 or 2mm id hose at that pressure.. not the most accurate guess but a worrying amount to me, even with the tps on you can feel it blowing out on your hands.. my hands are all that sensitive either, no cheek up against it needed
I would make sure there are zero leaks before taking it to them. In fact you want zero mechanical issues when you arrive there so they can smoke it and get on with tuning unhindered.
Time is money and it only ends up frustrating for both them and you.
I realize this wolverine but how am I to determine if this is an issue when the manufacturer is saying its normal and not to be worried about.. without getting a second opinion from someone who knows what there talking about such as yavus or mark at unigroup
it was alex I spoke to, he was quite helpful through the original purchase stages.
How would I have it proven to leak for them when they dissaprove of a static pressure test.. btw just to check before this goes further, the regulator on the compressor was showing quite a higher pressure but my assumption is that it was leaking out the valves as both my boost gauges in the car where what I took the readings off..
Yeah might do, I would prefer to have a definite that it's an issue first before complaining getting a new one and finding its the same.. i I called yavus he said it is normal and more common in aftermarket tb's as long as it's not excessive.. I have a feeling this may be excessive though
Yavus is going to tune so if he is happy with it then you should be sweet.
I have had cars back and forth from tuners over the years due to minor niggling issues and I was always lumped with the bill so I am a big fan of taking a week or so extra to get the car 100% mechanically right before tuning.
Yeah I would definitely like to have it 100% but I don't have any other way of having it tested, unless you have suggestions..
The car was being tuned and with a couple of other small faults, he said there was a loud hiss with high boost so I'm trying to find it, it was originally thought to bbe around the intake runners but with the compressor and some soapy water I think I've eliminated that, I found that I accidentally put the check valve in the wrong way for my carbon canister solenoid so I fixed that which was making noise with a bit of pressure from the compressor. I'm hoping that was it if not it must be this tb. I don't think I have another option other than back to the tuner
They already did smoke test it, couldn't find it as the smoke test only goes to 5psi and it doesn't pop it's head until beyond that, not sure if me testing it cold allowed it to not show itself I figured cold would be better as nothing would have expanded..
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
