the other day i uped the boost on my r33 so that it know runs around 10-11 psi but dont know if this model has a boost cut or i have some bad fuel, or maybe time for some knew plug. once it gets boost of 10-11 it splutters and pops through the exhaust. the plugs have done 25000 kms and the fuel im using is mobil.
https://www.sau.com.au/forums/topic/43586-boost-problem/
sorry as far as i know they have a boost cut for over boosting, I ran 14psi and no drama's, my car did suffer a broken land on piston 6, just when i bought it, because of a failing fuel pump, I found out after the rebuild that the fuel pressure dropped away under load. this was before I did any mods to it. a new 044 and she was a steady pressure again.
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-891084
Cav its your plugs, I just went through the same prob last weekend, car loosing power like spark or fuel cutting at anything higher than 9psi.
I replaced the plugs from fairly new NGK's to Double Platinum Autolits $90 all up and was advised by two different GTR specialist one online in N.Z skylinesdownunder forum to gap them to .66 So I took them as close as I could to that and guess what, it bloody worked, boost is fine all the way to 12psi - not game to take any further till I get a front mount.
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-894992
i found iridiums to be shite in my S13 ... soon as i upped the boost with an EBC it started missing. took the iridiums out and put in just your normal cheapy plugs that are like 12$ a set and it worked a treat. id say find out what is the cheap copper alternative to your plugs (NGK brand still though) and put some of them in at the same gap of .75-.8. for $12 it cant hurt to see if it is just crappy plugs.
yeah u need to dyno your car with a fuel pressure guage to test the fuel pressure. however, if you are upping your boost, it is a sensible option to upgrade your fuel pump anyway, especially if your planning to run the higher boost all the time and more power in the future. an 044 intank replacement is usually a good bet.
if it still has issues and you want to go for a Malpassi pressure regulator, do that after you've done the fuel pump. the Malpassi wont do much good if you have a stock fuel pump coz the pump will struggle to keep up the increased pressure anyway. i had a misfire in my DR30 skyline, changed plugs and leads, reset ecu, upgraded fuel pump, and still had a misfire at around 1bar. after fitting a Malpassi Rising Rate regulator the misfire is now gone.
try plug changing and see how you go to start with though!
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-902830
guys i have changed the plugs with a set of ngk cheapies and still the same. got my mates to watch the ass of it and it is blowing raw fuel out the exhaust. do they have trouble with the coils, maybe one doesnt like the increased boost (extra load). it doesnt play up till high in the revs 5000-6000 rpm. i can run 10-11 psi low in the revs with no trouble.
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-909192
  • 3 months later...
sorry dude havent sorted the problem yet, am thinking coils, or an after market computer its got me stuffed need to get it to someone whos playing with them all the time. i might sell it yet, that will fix it.
luckily it seems it was just my plugs...I hope you get yours all worked out though. Good luck!
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-1054385
Sounds like a fuel problem dumping too much fuel in and choking on it if its coming out the exhaust as a liquid :uhh: - SAFC ll can fix this.
Could be the coil packs, you'll need to tape them up with duct tape. Because the spark can ark out the side which results in the plug not getting the full spark. Do you run the black cover ontop of your coils - Saying Nissan 2498cc etc... ?
Hope that helps.
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-1054433
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
