the other day i uped the boost on my r33 so that it know runs around 10-11 psi but dont know if this model has a boost cut or i have some bad fuel, or maybe time for some knew plug. once it gets boost of 10-11 it splutters and pops through the exhaust. the plugs have done 25000 kms and the fuel im using is mobil.
https://www.sau.com.au/forums/topic/43586-boost-problem/
sorry as far as i know they have a boost cut for over boosting, I ran 14psi and no drama's, my car did suffer a broken land on piston 6, just when i bought it, because of a failing fuel pump, I found out after the rebuild that the fuel pressure dropped away under load. this was before I did any mods to it. a new 044 and she was a steady pressure again.
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-891084
Cav its your plugs, I just went through the same prob last weekend, car loosing power like spark or fuel cutting at anything higher than 9psi.
I replaced the plugs from fairly new NGK's to Double Platinum Autolits $90 all up and was advised by two different GTR specialist one online in N.Z skylinesdownunder forum to gap them to .66 So I took them as close as I could to that and guess what, it bloody worked, boost is fine all the way to 12psi - not game to take any further till I get a front mount.
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-894992
i found iridiums to be shite in my S13 ... soon as i upped the boost with an EBC it started missing. took the iridiums out and put in just your normal cheapy plugs that are like 12$ a set and it worked a treat. id say find out what is the cheap copper alternative to your plugs (NGK brand still though) and put some of them in at the same gap of .75-.8. for $12 it cant hurt to see if it is just crappy plugs.
yeah u need to dyno your car with a fuel pressure guage to test the fuel pressure. however, if you are upping your boost, it is a sensible option to upgrade your fuel pump anyway, especially if your planning to run the higher boost all the time and more power in the future. an 044 intank replacement is usually a good bet.
if it still has issues and you want to go for a Malpassi pressure regulator, do that after you've done the fuel pump. the Malpassi wont do much good if you have a stock fuel pump coz the pump will struggle to keep up the increased pressure anyway. i had a misfire in my DR30 skyline, changed plugs and leads, reset ecu, upgraded fuel pump, and still had a misfire at around 1bar. after fitting a Malpassi Rising Rate regulator the misfire is now gone.
try plug changing and see how you go to start with though!
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-902830
guys i have changed the plugs with a set of ngk cheapies and still the same. got my mates to watch the ass of it and it is blowing raw fuel out the exhaust. do they have trouble with the coils, maybe one doesnt like the increased boost (extra load). it doesnt play up till high in the revs 5000-6000 rpm. i can run 10-11 psi low in the revs with no trouble.
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-909192
  • 3 months later...
sorry dude havent sorted the problem yet, am thinking coils, or an after market computer its got me stuffed need to get it to someone whos playing with them all the time. i might sell it yet, that will fix it.
luckily it seems it was just my plugs...I hope you get yours all worked out though. Good luck!
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-1054385
Sounds like a fuel problem dumping too much fuel in and choking on it if its coming out the exhaust as a liquid :uhh: - SAFC ll can fix this.
Could be the coil packs, you'll need to tape them up with duct tape. Because the spark can ark out the side which results in the plug not getting the full spark. Do you run the black cover ontop of your coils - Saying Nissan 2498cc etc... ?
Hope that helps.
https://www.sau.com.au/forums/topic/43586-boost-problem/#findComment-1054433
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
