Hey guys
need some opinions. eventually in my R31 i want to run an RB20DET on straight gas, but i cant afford the new motor at the moment (as ive just spent 800 bucks gettin the head re-machined after a blown gasket - ouch). I am considering having the standard RB30 built for straight gas operation (ie pissing off the whole fuel system, gettin a bigger tank, removing the fuel tank and puttin the gas tank under the boot floor). Any ideas if this has been done yet, and if it is a good idea to do. I know i have to get brass valves and shit like that so it doesnt stuff up majorly, but im tryin to get rough pricing ideas cos no-one in adelaide wants to take me too seriously. i mean, they're more interested in poxy s13 silvias than a sleeper lookin 6 that could have a stomper of a motor underneath it (i apologise to any decent silvia owners).
Anyone who can help let me know
Matty T
If you're going to do it, it's worth doing a bit of research.
If it's done properly, you'll be very happy with the result, if it's done on the cheap, things will start to fall apart.
Check out gas research kits.
The most important thing in a gas only system is proper lubrication.
As far as octane goes, LPG is around 110 octane. Regular petrol 92(ish) octane and PULP 95(ish) octane
I had a VS V8 Commodore that towards the end was getting real heavy on petrol due to mods. I looked in to supercharging it as cams in the ol' 5ltr really do stuff all and use too much petrol.
I looked in to an EFI gas setup that used LPG Gas injectors. I also looked in to the gas research carbs which was cheaper but didn't yield as good results as the gas injectors.
The RB30 with a high comp 9.5:1, the twin cam head, a nice GT30 turbo would get it moving very very nicely on gas.
Cheers for the info so far guys...........Its good to know that i can get some people out there who take me seriously. Its almost the way to go now, my biggest thing will be is if i have to do anything to the ECU or not
  • 3 weeks later...
No you won't have to do anything to the ECU. Usually you have seperate gas computers and the switch that will switch from Gas to Petrol (or the other way around), but that's about all the electronics involved in a gas system. I've probably missed something out so someone correct me.
AFAIK a dedicated gas system is better that dual fuel, since there is a compromise on both fuels making less power etc.
Saw a RX3 or something in a mag that ran LPG, apparantly the exhaust ran really hot and it was always buring holes in it...or do rotors have a hotter exhaust temp anyway?
a lot of work, and for what gain?
There isn't too much work, i've helped do a LPG conversion and it isn't very hard at all just gotta get a mechanic or something to fit the tank and lines properly. Also gains would be cheaper gas prices!! also the EPA say that any car running straight gas is 100% under emissions, so there will be less trouble from them!
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
