  • Replies 105
Just saw on the panel that its offical, they even had a phone interview with Mark. We all sort of knew it was going to happen, but the confirmation has just made my day.
One thing is for sure, if you want to see Mark in a top three team, before the new rules come in, then the 2005 Melbourne Grand Prix is your last chance.
About 3 years ago.  Him and his girlfriend at the time walked away with hardly a scratch, the pilot and copilot not so lucky if my memory serves me right?
yes thats right in France, first thing DC was asked was "let me see your passport" stupid frenchies!!
ARE YOU FOR  REAL????????????????? How big a surprise is that. Surprised that BAR allowed that to happen, just as they started to show some promise!?!?!?!
What pisses me off more than anything, is this is the 2ND time within a year that Dave Richards has gone back on his words.
Halfway thru season 2003 - he finally accepted Honda's proto-type 19000 RPM engine had enough reliability to challenge CONSISTENTLY for podiums, and basically said "Next season we will have the engine to challenge for points, and two great drivers, in JV and JB" .. next second, JV is sacked!
Now he's more or less said the same thing about season 2005 - and gone n sold Button..
Perhaps Dave Richards saw $ to be made in selling JB back to Frank Williams. It's no secret that some of the smaller teams do this to raise much needed funds.
Still with Sato behind the wheel he's costing more $ than the R&D money BAR invest in their aerodynamics department. I think probably have new drivers for 05. Maybe Anthony Davidson will be promoted?
BAR Honda is actually one of the richer teams, with D.R owning Prodrive, and the vast $$$s of British America Tobacco propping them up.
TS is useless - yet he is the main reason Honda re-signed as engine supplier for the next 3 years..kinda good publicity to have a Japanese driver in a Jap powered car.
It's 99% confirmed Anthony Davidson will be promoted to #2 driver next season..
Yeah Davidson's been real impressive in Friday sessions. Maybe DR figured he'd do as good a job as JB and let him go cause he's worth more.
Oh, da Matta is gooonnnnne! That's good cause Briscoe is now official test driver as Zonta is promoted to driver for the remainder of 04.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
