Hey guys!
How are we all? Got. Strange brake problem please have a read appreciate good solid constructive answers.
Car: r32 gtst
Brakes: r33 callipers as rotors all around
Replaced rubber lines with braided lines
BM44 brake master cylinder.
So, we have installed brakes and lines no worries. Bled the brakes twice. Pedal still goes to the floor.
Have checked for leaks at all fittings between master and lines, steel lines to braided lines and then braided lines to callipers, no leaks.
Have bled brakes again - same problem.
Have replaced master twice (both second had options).
When you pump the brakes rapidly the fluid goes down in the master reservoir then returns to full level.
Any help would be great what on earth am I missing??
Cheers,
HAME.
Thanks mate doesn't it seem a little odd that I have tried three and all have done the same?
It does make a suck, blow sound when pressing the pedal but i think this is the seal on the booster.
Masters are often killed by people pumping the pedal all the way to the floor when bleeding. I've done it myself, and seen others do it numerous times. You can get away with it on a new MC, but an old one with cruddy build up at the end of the normal travel range can damage the seals if you push past that point.
The booster idea is also possible, and has likelihood, given that it only requires 1 failure rather than the failure of 3 MCs.
Hey!
Thanks for your replies! I will take booster off and inspect further.
With a faulty booster would this still cause fluid to go into the system then return (after pumping pedal 4/5 times constantly).
Brake pedal feels as if there are no brakes and there is no pressure on the pads.
When bleeding the brakes there was no pressure of fluid coming through my brake bleeder. After 6 odd pumps I open the nipple and it just dribbles not squirts.
Cheers, Hame.
Cheers, Hame.
I hope you weren't expecting there to be residual pressure in the lines after pumping the pedal THEN going and openign a bleeder nipple? The only time fluid comes out, and teh only time you should ever open a bleeder nipple, is during the down stroke on the pedal. It is a 2 man job. Just checking.
Did you bleed the ABS unit too if fitted?
What procedure did you use to bleed them, longest line to shortest or other way around? Did you bleed the ABS before or after the lines?
On a full open of the lines i bleed at least 4 times to be sure all the airs out.
Hey man, no abs unit on this model.
Yes I bleed longest line to shortest line from the BMC -
I have bled the brakes 3/4 times - still coming up with the same problem. Really odd :/ - fluid goes down then returns - soft brake pedal - goes to the floor.
checking.
No, it doesnt have to be a two man job at all
Ive gravity bleed brakes on all my cars
Its hard to know...but people change master cylinders and rarely have problems with soft pedals....but when people change calipers they often complain about spongey pedals. As someone posted you can damage the BC if you push the pedal all the way to the floor...but really you need to have scummy brake fluid and crap in there for that to be an issue. Its a problem for crap road cars, not generally a problem for well maintained Skylines.
So, when installing new calipers... if you are positive there are no leaks in the caliper, and by leak in teh caliper you have removed the pad, perhaps even rotor and checked no fluid is coming out the piston boots/seals then here is what I suggest you do.
Get worn pads or something similar in thickness and put them in. Pump the brakes up and give them a quick bleed with the pistons fully extended. Make sure you have dead pads or somethign same thickness in there as you dont want to push the pistons out.
So once you have fully pushed the pistons out and put pad against rotor, open the bleed nipple with hose connected, and push the pistons all the way back into the caliper. More often then not you will see bubbles. If you do....that has been your problem
Thinsg like usign old pads with the new calipers etc all hint that this may be the problem/ People that use new pads generally squeese the pistons all the way back when trying to squeeze in teh new pads and are more likely to displace any air that is sitting bhing the displaced pistons
Hey, again thanks for you reply! So compete this with all sides? I just picked up a pair of r33 callipers and bolted them on so use the pads that were in there.
Will give this a go also!
Hamish, before installing a master cylinder, whether it be clutch or brake, you have to bench bleed the master cylinder. Did you carry out this step BEFORE installing any of the previous three master cylinders?
Fit master cylinder in a vice. I lightly clamp in soft jaws with the bolt flange against the vice, fill with fluid, then using an extension or screw driver, pump the piston until fluid shoots from the ports.
Then fit master cylinder.
Two people are better for bleeding brakes (up, down, open, close), however gravity bleeding is fine with a 1-2 pump at the end to ensure all air is out.
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
