ok well i just got new motor to put into my s13 as my rb20 starting knocking going to be replacing it with a rb25
just got my self rb25det s2 did a a pretty good google search to find i have a late model rb25det r33 was a bit lost when i seen that it had a black plastic cas cover like a rb25 neo cas
now i want to know if the s2 rb25det loom cas plug will work if it the same plug? do the wires need to be changed? the motor is not a neo as it had s2 coil packs on it
thanks
https://www.sau.com.au/forums/topic/435903-rb25det-s2-later-model/
The series 3 r33 which were 97 models came with the rb25 that used the neo CAS, if you have a loom that is from that actual motor than it will be fine if not then you just have to change a few wires for it to work with the s1 and s2 rb25 loom.
If I wanted to I have a rb25det s1 head at home too could I just swap in the cams from that head and would they fit or any they diffrent ? So i can run that cas that came with the s1 head and not need to wire the neo cas ?
Yeah that would work.
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
