Hi Guys,
Brand new and unused -
These are to suite a R33 GTR
Mines pro front pipe = $800
Link tot he part: http://www.nengun.com/mines/front-pipe-pro
HKS Extension kit = $400
Link to the part: http://www.nengun.com/hks/extension-kit-gtr
Contact: 0448095760
common guys need this stuff gone !!! cheap as chops... and brand new
The extension kit will fit GTR 32/33 & 34
Hi guys just to clarify - the mines front pipe pro is made for RB26...
Features
  • Highest quality stainless steel construction
  • Professionally designed for superior response
  • 2x 70mm to 80mm outlet
Vehicle Compatibility Nissan Skyline GT-R (BCNR33), Nissan Skyline GT-R (BNR32), Nissan Skyline GT-R (BNR34)
SMS replied :)
OEM Front pipes can often be exposed (by tuners) as restrictive when GTRs are doing over 300wKw.
The Mine's front pipe shows no such restriction, and the sound is sublime (when combined with the right exhaust).
^ thanks for the useful info Terry :D
Mines front pipe pro - SOLD (pending payment)
HKS Extension kit still up for grabs !!!!!!!!!! quality parts common guys someone must want this for Christmas ;)
Some info on the kit taken from nengun website (for those of you lazy to click on the link):
When the blow off valve's actuator is activated, primary & secondary back pressure decreases the forced induction flow and results in a drastic engine power loss. The HKS Extension Kit is designed & developed to prevent such a power loss scenario. This extension kit improves the turbine efficiency & performance to elimiminate a sudden loss in engine power. This is acheived by separating the the main & bypass manifolds, and thus eliminating any exhaust interferences due to back pressure from the exhaust flow. This enable the factory turbine to perform efficiently since the loss happened nearer to the flange extension. This means the exhaust flow collector is attached to the lower portion where back pressures & exhaust flow intereferences are low. This also minimizes the exhaust flow resistance by expanding the size of the main manifold immediately after the turbine exit. This resulted in prevention of secondary back pressure and enable a stable forced induction pressure which will see improved engine power. The use of high quality stainless steel material in the extension kit's construction provides superior heat resistance, corrosion resistant, reliability, and durability.
Front pipes sold
Getting a lot of pms about the hks dumps - guys cant drop price any lower its $600 brand new please less low ball :domokun: and take it for $400 :yes:
  • 1 month later...
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
