R33 GTR 1995 VSPEC Edition Midnight purple PRICE DROP $20,000 FROM $24300!! NEED TO SELL
RB26DETT Forged Motor 337kw @ all four wheels on 19 PSI safe Tune With Dyno sheets
- CP Forged Pistons
- Eagle Rods
- ACL Race Bearing
- Brand new Forged Crank when built
- Head Cleaned out decked out
- Stock Cams
- Solid Lifters
- N1 Oil Pump Gears have been changed and strengthened
- N1 Water Pump
- Tomei Adjustable Cam Gears
- K&N twin pod filters
- Rajab Racing thick core racing Front Mout intercooler
- Rajab Racing Pully
- -5 Turbos
- Z32 Air Flow Meters
- 580cc Injectors
- Bosch 040 pumps
- Power FC Computer with hand controller
- TurboTech Boost Controller
EXHUAST:
- 3inch Jasma Exhuast System high flow cats
- Tomei Front pipes
DRIVE LINE:
- 5 speed Manual
- Excedy Button clutch changed 4 Months ago
- Adjustable camber arms
- Brembo brakes
- VSPEC stock suspension
WHEELS:
CE37s in bronze 18x9.5 + 12 all round wrapped in Bridgestone Potezna Tyres
- Garret 30psi boost Gauge
- Alpine Head unit/ USB/aux
- Alpine Speakers
- Alarm system
- Genuien Recaro SR3 bucket seat drivers side
- R33 GTR passenger seat
Car speaks for itself, to much money has been spent on this vehicle my pride and joy
To much to mention must sell
No JOY RIDES, strictly no SWAPS!
No finance owing history clean
$20,000 FIRM Price dropped from 24,300 !
call or txt me : 0432 282 125
for pictures check it out on carsales:
http://www.carsales.com.au/private/details/Nissan-Skyline-1995/SSE-AD-2471416/?Cr=0&sdmvc=1
doubt it. carsales link says not available anymore and the price on that ad was 16,500 (without wheels I think).
So probably sold for 16,500 id say- lot of car for that money :S
  • 2 months later...
. Would you be interested in swap for 2005 bf xr6 turbo. Has 320rwkw, 6 speed sports shift auto, clean, has almost 150000km comes with spool rods, cp pistons, arp studs, big actuator. Has a full exhaust, valve springs, injectors, fuel pump, oil feed line, zip kit in gearbox for firmer shifts, DVD player installed but haven't made the appointment for it to be wired up yet, gauges on dash, plazman 800 cooler, hot side cold side pipping, currently running on 13psi. If motor is built (parts supplied) it will handle 1000hp claimed by spool. Vic rego until November
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
