Hey all,
Never thought I would have to do this, but could everyone please keep an eye out for my pride and joy R34 GTT, it was stolen today from Ellenbrook between 3pm and 4:30pm. Highly modified, very recognisable. License plates are 1BKI 810.
Also please keep an eye out for this list of parts, I know how these things work:
Link G4 Plug-In,
Greddy Profec B-Spec II EBC,
Haltech 3 bar MAP sensor,
externally gated Hypergear ATR43 G3,
Turbosmart Compgate40,
1000cc Injector Dynamics injectors
, Plazmaman FFP,
Plazmaman 72mm throttle body,
JJR 3" bellmouth dump/front pipe,
VENOM 5" 100 cell cat,
3" custom Kermit Engineering exhaust,
Walbro 460lph fuel pump,
Continental ethanol content sensor,
GReddy FMIC,
AGP triple core alloy radiator,
stock GTR bov,
custom Pro Fabrications alloy oil catch can/radiator overflow combo with Earls fittings,
Splitfire coilpacks,
HKS fuel rail,
Sard FPR,
Speedflow braided fuel and turbo lines,
Performance Springs valve springs and retainers,
Tomei Type-B Poncams,
HKS exhaust cam gear,
Headtorque custom bronze valve guides,
ARP head studs.
Exedy Ceramic racing clutch,
custom driveshaft.
BC Racing BR series coilovers,
Kazama adjustable toe arms,
front strut bar.
18" Wolf S36's,
factory GTST brake calipers
, RDA slotted rotors F&R,
HEL braided lines,
EBC Greenstuff front pads,
Ferodo pads GTR rear wing,
Top Secret front bar
, custom retrofit projectors,
Sparco R505 racing seats driver and passenger,
Recaro seat rails,
ARK Design MFD
, Zeitronix ethanol content analyzer,
AEM wideband,
4x Shadow Pro series gauges,
custom carbon fibre bits.
PLEASE PLEASE, if you see it or hear anything, call the police or me on 0431047984.
I don't hold much hope of getting it back in one piece, but it's a very recognisable car with very recognisable parts, so I'll give it a shot.
https://www.sau.com.au/forums/topic/435962-car-stolen-from-ellenbrook/
Brick through the window, keys were hanging on the hook. I'm sure they were casing the place because I am home 99% of the time. I went out for an hour to pick my girlfriend up from work, came home to this.
Seriously regretting not getting a GPS tracking system. I was so close, then decided I was being paranoid and my car was never gonna get stolen.
Just to let everyone know, my car was just found dumped, thankfully in the same condition they took it. Nothing been taken off the car, and on initial inspection doesn't look like there's any damage. It's been towed to forensics tonight and I should get it back tomorrow arvo. Going to get it towed straight to my tuner for a full mechanical check before I drive it anywhere.
But to everyone that helped in sharing it, thank you so so much. It was through the 'Perth Crime Reports' Facebook Page that someone recognised the car and gave me a call. Can't even describe how much it means to me.
  • Like 1
f**k yes man!!!
good to hear!!!
Atleast someone called up about it!!
Makes me paranoid now :S, even though mine looks nowhere near as good as yours, still makes me think twice about it.
( my brother nearly got car jacked last week in glendalough :(, luckily my bro grabbed the keys before they noticed after he ran off with his GF. )
He also has a r34....man so many 34s being stolen...
A White GTR was stolen last night aswell..prob same peope...
Holy crap, I only just noticed this thread. So glad to hear you got your car back mate in one piece but also sorry to hear that you had to go through the ordeal of having your pride and joy stolen :O I've had it happen once before and it's not good :(
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
    • If you want to do the wiring, the GTT engine ecu has the same pinouts extra that the seperate TCM in the NA car has. You can literally grab the wires/pins that lead into the Seperate TCM and wire them into the corresponding pins in the GTT Engine ECU. You could then in theory Nistune it. I realised this when everyone put it in the too hard basket and I actually looked at the f**kin R34 manual. This is after I had previously had a seperate aftermarket TCM controller in my original N/A chassis car and a very built gearbox from a GTT, running a seperate Haltech engine ECU. I ran into this issue when I re-shelled the car into a GTT shell, so my aftermarket TCM was no longer plug and play, because the loom/modules were not present. I was pretty livid when realizing just how simple the original fix actually was. It sat for 3+ years at various workshops trying to find a solution. In practice none of this is a worthwhile idea for a lot of reasons, generally surrounding the shitness of the NA auto, the autos in general that come with skylines, and the NA engine and lack of gains. The gearbox is specced for the 2.5L N/A and barely at that level. If you have to pay anyone any money to do any of this, that is money spent on manualizing the car and it's not even close in terms of a comparison. Learning to drive manual is simpler than going through the pain of dealing with the N/A gearbox and he'll have fun to boot.
