2004 Evo 8Mr With 515Kw At The Wheels, 100K+ Spent
Hey guys, I'm contemplating selling my evo, some say there car is "capable" of making 500kw, but it's on 240kw, all u need to do is spend another 30k to get there but it's "capable" , this is one of those evos that have made the power it's capable of, and a lot of money, and time has gone into this car, well over 80k not exaggerating... If I sit and count what the parts cost plus labour it would be over 100k... And it's got the best of the best gear in it.. Rarely get driven, the only thing left stock in this car is the 6 speed box and diffs, it has 9 months nsw rego. Less than 1500km ago, Engine has been refreshed with new bearings, gaskets, etc, head has been refreshed as well. New complete precision turbo set up, new brake pads, new clutch, new tyres... Spent over 25k in the last 3 months.. So here's the mod list
price is $46000
PICS ARE HERE
http://s1037.photobu...s?sort=3&page=1
Car was built by ChasersMotorworks in Melbourne if you want to know a bit more about the history feel free to call them.
Engine Modifications:
- HKS 2.3L forged stroker kit. - engine opened up and refreshed with new bearings, gaskets, etc 1500km ago
- Precision 6466 turbo with custom powertune manifold- 1500km ago
Turbo smart wastegate 1500km ago
M&w ignition 1500km ago
5bar map sensor
- HKS type R intercooler kit
- HKS type R oil cooler kit
- Id 2000 injectors
Big fuel setup and surge tank, braided fuel lines
- Tomei adj. cam gears
- Tomei Procam 270/270
- Hypertune Intake manifold
- Hypertune throttle body
- Tomei fuel rail, braided fuel lines
- Sard fuel regulator
- PWR 57mm radiator
- Ferrea oversize valves, guides, springs,
- Solid engine mounts
- Heavily ported, machined, polished head- 1500km ago
- Motec M800 ECU
- Tomei Sump baffle
- Solid lifters
Suspension/Handling Modifications:
- Ohlins Flag L coilover suspension w/external res
- Alcon monobloc 6piston 365mm front brakes
- Alcon monobloc 4piston rear brakes
- Rose jointed
- All aftermarket suspension arms
- Adjustable sway, camber, toe, castor, bump, rebound etc
- Summit tower brace
- Summit boot bracing
- In cabin floor bracing
- Under car bracing
Drivetrain modification:
- Cusco front and rear Differential LSD's
- ORC twin plate carbon clutch
- Rays RE30 10.5x18 wheels
Yokohama AO50 semi slick. 265/35/18 driven only 3 times with these new tyres
Eboost 2
Oil pressure and oil temp gauges
Evo 9 front and rear bars
Varis side skirt
Varis rear wheel arch to tuck in the 10.5 wheels. Otherwise they will be sticking out like dogs balls.. The car had a time attack body kit on it which I took off but had to leave this only for the wheels.
Body is in good condition. 1 dent on it on the door. Some scratches on the bottom lip.
Interior is standard trim
This car is nuts to drive, it comes on like a motorbike, and handles like it's on rails, and with the Alcon brakes, it stops as hard as it pulls! Well not really but I haven't tried yet.. lol..
It's tuned on e85 and made 515kw @ 40psi, can make more power with another fuel pump, but I think 515kw is more than enough on the street.. It was tuned at maatouks racing.
Car is located in burwood, nsw please call 0410158440
Price is $46,000 a bargain considering the amount of work, and money poured into this car.
PICS ARE HERE
Edited by rami13b, Today, 10:38 PM.
post-86797-0-43163200-1386245479_thumb.jpgpost-86797-0-58918000-1386245490_thumb.jpgpost-86797-0-44387800-1386245501_thumb.jpgpost-86797-0-48020300-1386245520_thumb.jpg
No gt-r madness, you read wrong, my point is that there are people who advertise there car as "capable" of making 500kw plus.. This makes what it is capable of making, 100k has been spent on this car,
But if you think a turbo kit and stroker kit will get you 500kw think again, you will need another 30k.. That's what my point was..
Yes you did read it wrong, I wrote...
" some say there car is "capable" of making 500kw, but it's on 240kw, all u need to do is spend another 30k to get there but it's "capable" , this is one of those evos that have made the power it's capable of"
Some say, as in, some people selling there evos claim that there 240kw is just moments away from 500kw, and in reality it needs another mortgage to achieve this power...
Then I wrote, THIS IS ONE OF THE EVOS THAT HAS MADE THE POWER ITS CAPABLE OF
Did you still not read it right?
I understand what you mean, but this was a very unclear way of saying it.
What makes it so difficult for people to understand, is you meant to write "their car", but what you actually wrote was "there car".
"There car" does not fit in the sentence, so people start wondering does he mean "their car", "the car" or "there car". If you do not use the right word it makes it difficult to decipher what you mean.
  • Like 2
  • 1 month later...
  • 3 months later...
 Share
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
