Hey guys, I'm contemplating selling my evo, some say there car is "capable" of making 500kw, but it's on 240kw, all u need to do is spend another 30k to get there but it's "capable" , this is one of those evos that have made the power it's capable of, and a lot of money, and time has gone into this car, well over 80k not exaggerating... If I sit and count what the parts cost plus labour it would be over 100k... And it's got the best of the best gear in it.. Rarely get driven, the only thing left stock in this car is the 6 speed box and diffs, it has 9 months nsw rego. Less than 1500km ago, Engine has been refreshed with new bearings, gaskets, etc, head has been refreshed as well. New complete precision turbo set up, new brake pads, new clutch, new tyres... Spent over 25k in the last 3 months.. So here's the mod list
price is $46000
PICS ARE HERE
http://s1037.photobu...s?sort=3&page=1
Car was built by ChasersMotorworks in Melbourne if you want to know a bit more about the history feel free to call them.
Engine Modifications:
- HKS 2.3L forged stroker kit. - engine opened up and refreshed with new bearings, gaskets, etc 1500km ago
- Precision 6466 turbo with custom powertune manifold- 1500km ago
Turbo smart wastegate 1500km ago
M&w ignition 1500km ago
5bar map sensor
- HKS type R intercooler kit
- HKS type R oil cooler kit
- Id 2000 injectors
Big fuel setup and surge tank, braided fuel lines
- Tomei adj. cam gears
- Tomei Procam 270/270
- Hypertune Intake manifold
- Hypertune throttle body
- Tomei fuel rail, braided fuel lines
- Sard fuel regulator
- PWR 57mm radiator
- Ferrea oversize valves, guides, springs,
- Solid engine mounts
- Heavily ported, machined, polished head- 1500km ago
- Motec M800 ECU
- Tomei Sump baffle
- Solid lifters
Suspension/Handling Modifications:
- Ohlins Flag L coilover suspension w/external res
- Alcon monobloc 6piston 365mm front brakes
- Alcon monobloc 4piston rear brakes
- Rose jointed
- All aftermarket suspension arms
- Adjustable sway, camber, toe, castor, bump, rebound etc
- Summit tower brace
- Summit boot bracing
- In cabin floor bracing
- Under car bracing
Drivetrain modification:
- Cusco front and rear Differential LSD's
- ORC twin plate carbon clutch
- Rays RE30 10.5x18 wheels
Yokohama AO50 semi slick. 265/35/18 driven only 3 times with these new tyres
Eboost 2
Oil pressure and oil temp gauges
Evo 9 front and rear bars
Varis side skirt
Varis rear wheel arch to tuck in the 10.5 wheels. Otherwise they will be sticking out like dogs balls.. The car had a time attack body kit on it which I took off but had to leave this only for the wheels.
Body is in good condition. 1 dent on it on the door. Some scratches on the bottom lip.
Interior is standard trim
This car is nuts to drive, it comes on like a motorbike, and handles like it's on rails, and with the Alcon brakes, it stops as hard as it pulls! Well not really but I haven't tried yet.. lol..
It's tuned on e85 and made 515kw @ 40psi, can make more power with another fuel pump, but I think 515kw is more than enough on the street.. It was tuned at maatouks racing.
Car is located in burwood, nsw please call 0410158440
Price is $46,000 a bargain considering the amount of work, and money poured into this car.
PICS ARE HERE
Edited by rami13b, Today, 10:38 PM.
post-86797-0-43163200-1386245479_thumb.jpgpost-86797-0-58918000-1386245490_thumb.jpgpost-86797-0-44387800-1386245501_thumb.jpgpost-86797-0-48020300-1386245520_thumb.jpg
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
