danny14 Posted December 7, 2013 Share Posted December 7, 2013 hey guys as it staes does anyone know the exact dimensions of the rb HKS AIR FLOW LESS ADAPTER i want to make some anyone got a sketch of the dimensions so i can make them the correct size cheers guys Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/ Share on other sites More sharing options...
Piggaz Posted December 7, 2013 Share Posted December 7, 2013 Couldn't you just use the size of the AFM seeing that its replacing them and no mods are necessary? Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136195 Share on other sites More sharing options...
Mick_o Posted December 7, 2013 Share Posted December 7, 2013 ^^this^^ measure the AFM's problem solved Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136197 Share on other sites More sharing options...
danny14 Posted December 7, 2013 Author Share Posted December 7, 2013 yeah i would if i wasnt in the desert atwork ha ha i thouht the inside dia was bigger than standard afms ? Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136216 Share on other sites More sharing options...
scotty nm35 Posted December 7, 2013 Share Posted December 7, 2013 Probably, as I doubt you would run 5mm wall tube for the AFM delete pipes. Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136288 Share on other sites More sharing options...
danny14 Posted December 7, 2013 Author Share Posted December 7, 2013 can anyone tell me the length and inside dia for these hks items . Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136291 Share on other sites More sharing options...
danny14 Posted December 7, 2013 Author Share Posted December 7, 2013 s^^^^^ so is the pipe size 3'' or what does anyone know Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136292 Share on other sites More sharing options...
scotty nm35 Posted December 7, 2013 Share Posted December 7, 2013 Japan use the metric system, as do most other countries. I seem to remember 65mm, but not sure. Why don't you have a search around... Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136315 Share on other sites More sharing options...
Piggaz Posted December 7, 2013 Share Posted December 7, 2013 Brb. Ill put up a rough measurement. 60mm x .... Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136403 Share on other sites More sharing options...
Piggaz Posted December 7, 2013 Share Posted December 7, 2013 60 mm internal x 125 from face of flange from the air box to the tip of the end. Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136404 Share on other sites More sharing options...
danny14 Posted December 7, 2013 Author Share Posted December 7, 2013 ok thanks dont think you coud email me with an outline of the flange exact size on a bit of paper with bolt holes? [email protected] Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136542 Share on other sites More sharing options...
Piggaz Posted December 7, 2013 Share Posted December 7, 2013 ok thanks dont think you coud email me with an outline of the flange exact size on a bit of paper with bolt holes? [email protected] Ill see how hung over I am tomorrow. Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136737 Share on other sites More sharing options...
danny14 Posted December 7, 2013 Author Share Posted December 7, 2013 ha ha thanks mate would be much appreciated cheers again Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7136851 Share on other sites More sharing options...
danny14 Posted December 10, 2013 Author Share Posted December 10, 2013 any luck man ^^^^^ Link to comment https://www.sau.com.au/forums/topic/436041-hks-air-flow-less-adapter-dimensions-rb26/#findComment-7139501 Share on other sites More sharing options...
