11 cars confirmed so far! Im sure we can do better than that lol We had 19 at the last one to Newport.
I reckon Maccas on the way to Wollongong. Well see what the majority would like and depends on how many joining in. I reckon there will be a lot of last minute cruisers.
Think we need to change the meet up point for the local guys as we won't all fit
I actually thought about this, that little bit of road in the left hand lane probably won't be enough for more than 10 cars. What about a second meeting point at sylvania maccas? It's just down the road...
I was talking about the second meeting point Daniel. For all the hobbits haha. It's only a tiny bit of road, if there's anymore than 10 cars I'm not sure where they'd be able to wait for us?
I think further up the highway in Sylvania you can technically park in the left lane but nobody ever does, you could easily fit 20 cars there.
Or just the entrance to the park? near loftus oval.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
