Ok so I have brought a Weldon speed pump controller to try and quieten down my Weldon 2025 pump
The controller says it is PWM controlled but the wiring diagram shows it as a closed circuit with a POT dial to preset pump speed and a toggle switch for race mod
I want to hook it up to one of the spare PWM outputs of the computer and let the computer run the controller automatically
Has anyone used or hooked up the Weldon 14000 speed controller and be able to tell me which terminal on the controller to hook into for the computer output ?
https://www.sau.com.au/forums/topic/436068-weldon-14000-pump-speed-controller/
It's not quite as simple as that...
Best you could do without getting super trickery would be to use an analogue output, set up as a load/rpm/boost switch to provide ground to the controller in place of the 'race switch'.
The computer I have has a fuel pump strategy already built in but it runs though the fuel or IGN out puts as a PWM
I have had a email from Jim at weldon telling me it will not take a PWM input an I don't have any analog outputs left( I don't think anyway) so what I was looking at doing is getting a 12v map sensor as the reference input instead of the potentiometer then have the computer set a 12v output to turn on "race" mode when the car goes over 21psi boost ( low boost is 19-20 )
The Hobbs is on/off, where a map sensor signal increases with boost which will increase pump speed as it climbs, basically an automatic potentiometer, the input of the controller is a variable, the more voltage inputted the faster the pump spins
Though you could use the Hobbs to trigger "race" mode
Sounds entirely to much f-ing around for veeeeery precise fuel pump speed control.
Any particular reason you wan't this level of control over your fuel pump? I would have thought 2 speeds would be more than sufficient.
To mee it seems like alot of effort for little to no gain, another system that gets needlessly complicated and can have catastrophic consequences...
... personally, I like knowing my 2345a is running flat out and that the fuel will be there when I need it.
PS fuel lab is shiiit, Weldon is best!!! ha ha ha
realistically the OEM fuel pump speed is on/off by nature... at idle and low rpm its spinning at a lower speed then as soon as it gets over a set rpm it ramps up to a higher voltage. This is what i would be setting up with the after market pump...
the pump is awesome piece of gear, just very very............very loud, and given it is a street driven car I want to make it as quiet as possible so when sitting at traffic lights I'm not getting to much attention, in a blue R34 GTR :whistling:
we had it on the dyno the other day and the fuel circulated so fast it just heated up the surge tank, but then that could have also been because the intank E85 pump wasn't working
the controller is just a little less flexible then I wound have though and when I looked in to the controller it said it was a PWM unit but no where I found said it wouldn't take PWM input
and did I mention the pump is VERY loud, louder then the 4" exhaust
that's right and I can do this with the Weldon controller, but my computer is set to run full variable so I can set it to run at any set level at any given RPM/load so I can set it up to run the pump at say 10% more flow then needed through the whole rev range
so when sitting at traffic lights or in a car park the pump is barely turning meaning I'm not just pumping fuel through the motor back to the surge tank heating the surge tank up
for what its worth i run 2x 044 as mains with a walbro lift, fuel circulates at constant voltage to the pump. i also have fuel pressure sensors and temp sensor in rail and surge tank... never see fuel temp rise above 35 degrees max with e85, no fuel cooler
That was going to be my setup till I was told 044 prefer to be gravity feed and my setup wouldn't allow for that so I went the 2025
I have the Walbro E85 intank as a lift pump which flows 500L/H 0-30psi feeding the surge tank and the Weldon which flow 590L/H@ 80psi and 620@ 50 psi, the 044 @ 80 psi flow 260L/H
Slowing the fuel down isn't really that big of an issue as I drove the car for the first time last night with the new setup and after 45min drive the surge tank was just warm but the noise, I have to do something about that which is the main reason for slowing the pump down
I have fuel pressure and temp sensors also, I'll have to go into the logs an see what the temp got to
I went to MSCN to buy the pumps and a bracket told them what I was doing with them and they told me not to do that with the 044s putting them selves out of a sale, so given that I'd tend to believe what they said
I then mentioned it to my tuner and he backed them saying the same, 044s should be gravity feed, both company's sell 044s neither sell Weldon and both told me for my setup go Weldon or Aeromotive
044s like to pump fuel not pull fuel, thats just what I was told
In my opinion weldon make some of the best fuel pumps available... from a delivery, engineering and reliability standpoint. Much better option than multiple o44's.
Yeah they are a bit loud, I put mine in a sound resistant case for long trips.
I've always been a big believer in single pump arrangements...
I'll PM you with a solution.
Cheers
Justin
Cheers
Justin
We use the 2033-A pump as a lift pump in the race car and it is quite loud!
We had a few lift pump problems with running methanol. So far the Weldon pump is proving its worth nicely, if its reliable then the noise isn't important, at least in a racing environment.
Thought of Weldon after reading a few of your posts about these pumps Justin. They are top notch!
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
