RB25DET
Changed out my series 2 motor with a series 1 motor due to a failing bearing. Motor is still physically okay, and running gear that has been removed is working
I have the following parts available. Pickup from Dandenong VIC or I can post at buyers expense.
Starter motor - $70
Alternator - $80
Power Steering pump - $80
Throttle Body - $80
JJR Dump Pipe to suit standard turbo (6 bolt Nissan rear) - $100
post-59604-0-81054000-1386481502_thumb.jpg post-59604-0-43354000-1386481535_thumb.jpg
Standard log manifold - $150
Standard RB25 blow offf valve $80
Timing Belt Covers Top & Bottom (painted blue) - $100
Fuel Rail - $50
Xtreme Heavy Duty Cushion Button Clutch (80%ish meat) & Pressure plate - $400
post-59604-0-66551600-1386481775_thumb.jpg post-59604-0-94193000-1386481804_thumb.jpg post-59604-0-57406800-1386481832_thumb.jpg
Coilpack bracket (S1) - $25
Coilpack harness (S1) - $40
Ignition Module (S1) - $80
Injector harness (S1) - $40
Crank angle sensor (S1) - $150
Oil Filter Housing [between block and filter] (S1) - $70
Set of 4 White Yokohama Advan TC2 rims. 18x8.5 +25 front / 18x9.5 +29 rear. Stud pattern 114.3 x 5. light weight 8 -9kg.
The front rims have Advan AD08 tyres 245/35/18 on them, the inside shows signs of camber wear so those tyres would need replacing very soon, however they still appear very grippy. The rear rims have Nitto NT05 tyres 275/35/18 on them which are completely worn and need replacing.
The front right has a small crack in the rim (on the middle part where the tyre is seated) which has just temporarily been repaired but will need a bit of welding. I got quoted approx $110 to have it fixed.
The front left rim has some light gutter rash on the outer edge of it, but it should be fairly easy to clean up.
Other then that the paint and rims themselves are in good condition
$1800
post-59604-0-41477300-1386482459_thumb.jpg post-59604-0-77908300-1386482489_thumb.jpg post-59604-0-13562000-1386482516_thumb.jpg
SMS me on 0458762075
Brent
Have you still got the whole head ?
Sent from my iPhone using SAU Community
Hey mate, I just sent you a PM. I have it still. I sent my phone number in PM too.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
