As stated in the title I have a PowerFC Pro with hand controller to suit R32/33 rb26's.
Price: $1100
The difference with the pro model is that it uses an ignition cut rev limiter instead of fuel cut on normal pfc's (this is to help prevent knocking) and also it has a launch control system. The launch control works by allowing you to set a secondary, lower rev limiter that only kicks in when the car is stationary (eg 5000rpm). Then once youve moved over 0kph, it goes away allowing you to rev to the regular limiter (eg 8000rpm) so that you can get perfect launches every time. These ecu's are long discontinued and quite rare nowdays. It also comes with a hand controller.
Secondly are a pair of Nismo afm's.
Price: $500pr
The nismo afm's are the only bolt in upgrade for your standard afm's as they are the same size and hence fit into the standard intake piping (which means will also work with stock air box).
Items are only being removed as I will be upgrading to a Haltech ecu which also doesnt need afm's.
Both items are in Adelaide and can be shipped at buyers expense. I will sell the lot for $1500 delivered if someone wants all of it.
Contact via PM, Cheers.
https://www.sau.com.au/forums/topic/436090-sa-powerfc-pro-nismo-afms/
