hi I have a vl with a rb25det running standered ecu turbo injectors it has yellow jacket coils 3 inch exhaust gutted cat a micks metal craft forward facing plenum self raising for brand new intercooler an pipping runs at 11 pound using a boost tap...
now the problem I'm having is once it has warmed up its sluggish an looses power here's a list of wot I have already changed...
fuel pump Bosch 040
-7 spark plugs gapped at 0.7
has no boost leaks wot so ever
brand new Nissan tps
new afm
tried another ecu also
I did have a coil arking on the engine not the plug but I wrapped it in electricall tape and is working fine now an is running on all cylinders
I really just need advice on wot it could be possibly knock sencors? ? I'm lost for idears it runs fine till it hits it's normal running temp an still drives normal but wan I wanna get into it it will hesitate than go but wan it gets to about 5500-6000 it's just shutters an losses power it does it threw all gears but wan driving normal it's not very noticeable I've owned the car for over a year now an this problem has only started happening in the last month at first it was barly noticeable but now it can't be driven hard at all
any help will be appreciated
https://www.sau.com.au/forums/topic/436094-need-held-rb25det-lossing-power/
that is text book coil-pack troubles. From the symptoms of power loss at those revs to also being occurring at normal operating temps.
Also if you've had trouble with the coils before then id say tape is a temporary fix. Yellow jackets don't have the best reputation.
Id also be inclined to check your earthing as if the coils were pretty new then you might not be earthing correctly forcing the spark to do weird things.
Beyond this, potentially AFM (clean the wire as well as check the internal solders for a dry solder). But id put good money on coil pack issue.
hi I ran it for about a week with the spark gapped at 0.8 than a week a 0.7 an there was no noticeable differances between the 2 an spark plugs them self are only two weeks old an are nkgr dont remember all the part number on them but they end in -7...
does any one in Sydney have a cheaper set of rb25 series 1 coils for sale let me no cheers
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
