2860 ~5s with GCG 18psi actuators (the best ones imo) and heavy duty bracket so there's no flex and boost line is very straight with great control with no drop off at the end,i also have modified inlet pipes that bolt to the front of the turbo plus made an insert so there's no step into the turbo which makes them flow like the HKS 2530s and increased spool up dramatically $1500
Ported and flowed and match ported stock exhaust manifolds to maximize spool up $250
Tomei Expreme dumps latest ones used $450
Apexi front pipe dual 70mm into 80mm $250
Power FC for R34GTR with handset $750
Sard 700cc injectors $400
Z32 afm's with plugs in as new condition $400
R34 gtr airbox complete with cold air inlet duct modifed to bolt on z32 AFMs like stock AFMs $300 or $650 with complete with Z32 AFMS and plugs
Stock airbox complete with stock AFMs plus cold air inlet $350 or $250 with out AFMs
Custom alloy pipes to replace the twin turbo pipe just like the nismo style but a 1/4 of the price $450
Drop in Trust cams 264 duration with 9.1 lift $250
JUN oil pump $700 pump has been thoroughly inspected and crack tested the gears are like brand new! i bought a tomei one for the right price so i swapped them over
Trust intercooler 75mm to suit R34 GTR perfect condition $500
For R32GTR there is a brand new Power FC $850
Mines style rocker cover baffels brand new (may be genuine Mines i just cant remember as i bought them a long time ago from justjap) $220
Brand new nitto head gasket 1.2mm thick $300
Engine mount $50
all parts done aprox 6000 klms (unless stated otherwise) made 340 klw at 20psi full boost at 4000 rpm on pump fuel,gone to a single turbo set up now there for selling the lot
located near Gosford NSW i can also meet up on the northern beachs in Sydney
​will post at buyers expense and if you want to pay with paypal thats fine as long a you cover the fees on my end
Hey mate , are the cam baffles for sale? Can't see price or info on the ad. Interested on exhaust manifold as well. Pm me.
Thanks Ryan
Edited by wld093
These pipes and the insert are easily removable and the pic where im holding the short pipe is the unfinished product it was just showing the mesh welded in the part coming from the blow off valves,the pipes look factory after i finished them i will post more pics tonight
The Trust inter-cooler is the older style which were the best by far ( the current ones are made in china i believe) it will work great on any engine making up to 400 klw at all 4 wheels it has cast formed tanks and is perfect for track cars or street cars,when i swapped to the nismo 100mm cooler boost def came on LATER and inlet temps were no different on my MFD
VERY HARD TO FIND THIS VERSION!
For those who wanted to know if the baffels are aftermarket they are actually GENUINE MINES TRIPPLE FLOW items selling as a complete kit
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
