plumb the wastegate back into the exhaust and it will be quiet again, are you running a stock turbo cause it sounds like it..
Not stock turbo, pretty sure it's a ebay turbo (Was there when i bought the car). [i'm aware the oil feed line isn't the best and i'm ordering braided hose for anyone about to comment on it]105y99l.jpg
I've done some research and some people use moto exhaust silencers plumbed to external to quiet it down, anyone done this? also can i change the way the gate opens? i'd prefer it at higher rpms oposed to when im just trying to overtake people.
Edited by iTwix
someone shoot me. please.
Hey man, you had to learn at some point too. I know alot about n/a engines but i'm fairly new to turbo's although i'm getting there. Why do skyline drivers always condescend on people :\
Edited by iTwix
Don't worry about those people. Majority of them are kids sitting behind a computer ragging on others ignorance to make themselves feel like their dick is bigger. Learning takes asking questions.
I'm gonna guess that silencer you're referring to would kinda work. It's called a SuperTrapp. Good mufflers and tunable depending on how many rings you run. Seems like a lot of trouble and not a whole lot of room to do so. Google SuperTrapp and look for the dimensions. Measure it out. Before you start playing with spring rates in your waste gate, probably want to look at howstuffworks.com and search turbo. It will help you understand majority of the basics and some advance calcs on forced induction.
But when it comes down to it and a lot of others are explaining to ya....plumb it back into your down pipe. I'm sure any muffler shop can help.
Thanks man, i appreciate the helpful post. I think plumbing back to downpipe may be the best option, what is the horsepower difference? I started around 320hp and it feels like i've lost about 50 hp with the gates current setup, will downpipe plumbing effect performance oposed to exhaust vent to atmo?
Edited by iTwix
Have you tuned it yet since installing the external?
Not yet, i have a microtec lt-12 ecu but don't have the plug play cables yet to edit setups.
Also noticed you're say hp instead of kW. You must live in n. America.
I was originally living in canada but i'm living in perth now.
Edited by iTwix
Doing a waste gate upgrade like that requires tuning. You went from whatever internal which is normally 5-7psi (unless you have a boost controller) to whatever you received the waste gate as from manufacture. Externals are much more adjustable and tunable. That's why an external waste gate was engineered for, to gain more options for tuning. A lot of people don't realize how much that spring inside can alter your turbos personality. You really need to get the car professionally tuned if not done yet.
One of the reasons i haven't dumped the car on a shop yet is a pride thing, when i got the car i had to do alot of work replacing hoses and rerouting things properly (there was no nipple for boost on turbo or in piping) causing it to boost cut really bad. You can see in above pic that my oil feed is pretty sad, needs a 90 degree fitting and braided hoses to avoid kinks/melting. Couple hoses had some shocking frays and was dripping little bits of oil. So i'm making sure that everything is in good nick and wont be an issure before milking power out of it.
Another reason would be the cost, i simply don't have 1 grand to drop into tuning right now and am saving my pennies until i can get there, until then i'll be working on it the best i can learning as i go.
(pic is oil return line from turbo, one of the many pipes i've been replacing with proper silicone heat resistant pipes).
lol....typical noob comment...
lets put it this way...muppet removes exhaust pipe at engine...then complains engine is too loud...and we are meant to take him seriously....?
lets put it this way...muppet removes exhaust pipe at engine...then complains it is too loud...and we are meant to take him seriously....f**k off...
i didn't remove shit, i'm dealing with what i got. You have a high post count for someone that spits usless info, why don't you put it on your resume and see how far your condisending attitude gets you in life.
Edited by iTwix
Yo people,
My problem is that my R33 gts is way to loud after hooking my external wastegate up. My skyline has a straight through exhaust which is loud itself, but not overly loud. When i hooked the waste gate up it made such a noise that it pissed off anyone within a mile of me,
well thats not what you told us is it?
At what point did i remove anything? wastegate was already hooked up to exhaust manifold, just didn't have the nipple on the pipe from the cold side of turbo routed to the wastegate to add pressure to open it, meaning it was boosting uncontrollibly and fuel cutting/backfireing when it overboosted. Hence the need for the wastegate to be hooked up so it can releive pressure, yet i'm discussing ways to silcence the wastegate noise as it's obviously noticable as external atmo gates are. You can add your opinion about the car, not about people in the thread because who the f**k cares about that.
Edited by iTwix
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
    • My son recently purchased a 93 Skyline GTS25 (NA), I am hoping to get some insight as to what potential this car has.  I have auto mechanical experience, and I am capable of working on this vehicle, but I know nothing about it.  Where's the best site to purchase parts (maintenance, repair, upgrades)? What kind of upgrades are available?  Thanks again and I look forward to any information that you all have to offer!   Darrick
    • This is a pump I have used in the past; no oil ever leaks or gets past the regulator plug.I was trying to understand what caused Nissan to not only mention it in their manuals but to also state it's a replacement part yet the part cannot be found on my pump or on any new pumps and there doesn't seem to have ever been a replacement part#.  First time I've noticed something strange like this from NIssan.
    • yeah I have brown peeking out from in between some metal sheets close to the hood hinges. Strut towers look fine, even around the edges. some images https://imgur.com/a/brGt3Tu the one that looks the worst is the panel(s) going away right near the firewall on the passenger side, from underneath. Driver side does not look that bad.
