I finished putting my bottom end together yesterday but it wasn't till I'd finished and turned the engine around to look at the top that I realised how far the peak of the pistons protrude out of the block.
Has anyone done a high comp RB and seen that amount of piston out of the block? Obviously I'll find out when I sit the head on but is there enough combustion chamber to even fit that much protrusion??
The pistons are custom CP 9.5:1.
I'd appreciate some input!
Ok cool. I googled images but couldn't find any decent shots showing so much protrusion.
I'll gently sit the head on when I get a chance and I'll soon know. I'll be nervous as all hell the first time I turn it over with the cam belt on!
Thanks for the responses guys, giving me a little bit of hope!
Thanks god it's got the valve reliefs in the pistons cause I think it's going to need that extra 1mm of clearance!
As a trial engine, I'm running RB25 pistons with the deck skimmed 30 thou to get them up flush with the deck. Also gives 9.5:1 compression and I have a similar amount of piston sticking up past the block as you do so I think you'll be fine.
To get 9.5:1 on an RB30 bottom end with an RB25/26 head you're running about the same amount of piston dome as a standard RB25/26 so you shouldn't have any issues.
Fit the head on with a few weak mockup valve springs and the cams your running to the correct valve clearance, use a old known thickness HG, put some plasticine on the pistons, fit cam belt on and very gently turn the engine over by hand for 2 full turns feeling for binding.
You want about 60 thou or 1.5mm valve to piston minimum clearance, better 80 thou or 2mm, any less than that is very dangerous and you might have them meet at high RPM....more clearance the better to allow for rod stretch and valve float.
As a trial engine, I'm running RB25 pistons with the deck skimmed 30 thou to get them up flush with the deck. Also gives 9.5:1 compression and I have a similar amount of piston sticking up past the block as you do so I think you'll be fine. this is what I have done, RB25 14cc dome tops with 26 head and 9.53:1, no issues yet and the engine has been running since January
To get 9.5:1 on an RB30 bottom end with an RB25/26 head you're running about the same amount of piston dome as a standard RB25/26 so you shouldn't have any issues. there is actually more clearance with the 30 bottom end then the 25/26, cause 500cc getting compressed at 9.5 parts to 1 means 1 is a bigger area then 428cc getting compressed 9.5 to 1
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
