Brand New In Box. Rb25 Link Ecu, Tomei 264 Poncams, Npc Clutch Rated To380Rwkw Clutch
For Sale - All brand new and still in box to suit rb20/25
Link G4 PNP computer purchased below. Unused still in box with warranty. Also comes with loom ($62)
http://www.garage7.com.au/home/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=2944&category_id=611&option=com_virtuemart&Itemid=53
Tomei Poncams to suit non-neo rb25 and rb20. 264 cams. Please note these are much harder to get than the common (and much cheaper) 256 cams. Will also come with exhaust cam gear (inlet not needed) purchased below:
http://www.cj-motor.com/store/index.php?main_page=product_info&cPath=11_40&products_id=117
NPC heavy duty cushioned ceramic clutch rated to 380rwkw
http://www.garage7.com.au/home/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=938&category_id=396&option=com_virtuemart&Itemid=53
Please note all items were bought here in Australia from reputable companies listed above and still have a valid warranty.
Prices
computer and loom $1450
Poncams plus exhaust gear $890. Also have timing belt for sale
clutch $650
email - [email protected]
So do these cams just drop straight in without modifying anything?
These cams come in three options of lift 256,264 and 270. The 270 need modified or custom valve springs while the 256 and 264 are "drop in cams" without needing to modify anything. The 264 is the biggest you can go without needing to modify anything - which is the exact reason why I bought them.....
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
 Share
    • VCAM doesn't really increase peak power, it just widens the powerband. So if you were giving up power with adjustable cam gears to get better low-end response yes in theory it "increases power" but otherwise not really. Stroker kit might put you in a more efficient region of the compressor map which will get you more power but at say 7000 rpm I'm not sure that much will change. The original HKS GT2530, -5s, and GTX2860R gen 2 are all roughly the same kind of turbo. If you want 600 horsepower those are the turbos you need. So 500 whp. Just expect to spend some quality time trying to figure out intake/exhaust piping. The "twin turbo" pipe is an obvious place to start. Make sure the actuator preload and all of that fun boring stuff is set up correctly. Throw a VCAM step 2 at it if you want good response, 2.8L stroker too. If you're not actually wedded to 500 whp all the time you can barely get there with -7s or Nismo R3 turbos, you just have to run E85 or race gas and run them hard:
    • It's used in the GT-R, GTST/GTT, and Z32 VG30 NA + TT versions. Nissan still makes them new, they're not cheap but they're not expensive either. Personally I would just get something direct-fit and be done with it but I'm not that handy at fabrication.
    • FS5R30A the nav box isn’t it? I did think about those. Any issues? I wondered if the bell housing off an rb30 patrol would work as they are the same gearbox but with a transfer I believe.
