Nissan Stagea C34
Series 2 RS (rear wheel drive) with rb25det neo engine and 4 speed tiptronic trans
Built 11/2000
151,xxx kms
Pearl White paint
Unmodified and in excellent condition
Imported by Synergy Motorsport. One owner with books and full service history also done by Synergy
Climate control
ABS
VLSD
16" Alloy wheels with good tyres
Twin sunroofs
HID lights
Privacy glass
6 stacker CD
Stagea floor mats
Alarm / Immobilizer
flip flop center console
Cargo barrier
Cargo cover
Tow bar
9 months rego
Everything works, just jump in and drive. Only selling due to recent upgrade
9k ono
post-12234-0-61999500-1386579784_thumb.jpg post-12234-0-46090200-1386579793_thumb.jpg post-12234-0-34713900-1386579802_thumb.jpg
post-12234-0-27859900-1386579810_thumb.jpg post-12234-0-32068000-1386579818_thumb.jpg post-12234-0-29969400-1386579826_thumb.jpg
https://www.sau.com.au/forums/topic/436138-nissan-stagea-c34-sa/
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
