For circuit racing, I would go the 2835 too. The GT-RS is nice as well, although I don't know much about it. Does anyone know if it bolts straight on?
If I was in the market for a new turbo, it'd be a very hard decision between the 2535, GT-RS and the 2835 for me (I don't circuit race though, I'm talking about for the street).
https://www.sau.com.au/forums/topic/43614-which-turbo/#findComment-890481
Roy, shall do some super sprints to start and go from there do a dutton as well etc not at this stage will i be peeling paint of my side with others just yet
Fatz ,just wot i thought most of it will be up above 4k (its the only way to get the car to smoke along
Guyz there are some turbos that i did not even think about sure know how to screw my head up (lollollollol)got to decide soon gets the cage in soon then all the other shoit as well
https://www.sau.com.au/forums/topic/43614-which-turbo/#findComment-892297
Latest development from Garrett is the GT3071R . This has a 56 trim GT35 compressor wheel , good for 44lbs/min flow or about 400 + Whp . The turbine is a GT30 84 trim (same as GT3037/GT3040) . The compressor cover is a .50AR TO4E and the turbine housing can be any GT30 compatable in T3 flange .63/.82/.106 and in T25/28 flange from HKS .61/.73/.87 etc . Brett Lloyd from GCG in Sydney is looking into these at the moment . For pics see ATP turbo.com (in US) and read the write up on the Lancer Evolution 8 kit featuring the GT3071R turbo . ATP claims 375whp on the Evo 8 with modest ? boost and their .63 exhaust housing , and spools 2-300rpm later than stock . Price is $1325 US or $1050 US without the exhaust housing .
https://www.sau.com.au/forums/topic/43614-which-turbo/#findComment-892306
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
