I managed to get a gktech fan cheap during one of their sales a few weeks ago.
I installed it on the weekend, and have driven it for the past 3 days.
The only temp gauge I have to go off is the oil temp gauge on my GTT, and that has dropped from 82-85 down to 75-80 on normal driving, so I assume the whole engine is being cooled better with the gktech fan.
However, the fan does seem pretty noisy. I've had a viscous hub fail on the fan before, which makes it sound like a EL Falcon all the time! With the gktech fan, it has got that 'roar' back of a dud hub on the fan. Even at low to mid rpm, the fan is roaring.
I'm not sure if its just the fan blowing more air, or if my hub has shat itself with the change of fan blade/load. I haven't had time to swap the old fan back yet, and decided I'd seek an opinion before changing it over.
If anyone else has one I'd appreciate your feedback
Cheers, Chris
https://www.sau.com.au/forums/topic/436163-gktech-fan-on-rb25/
Interesting to hear some feedback from someone using one! I have one sitting in my car that i was going to fit... Not sure if i want it much louder tbh but i guess the cooling will be worth it for summer anyway! Decisions :)
Mines loud enough to hear it in the cabin with the windows up, although my exhaust isn't very loud.
To compare it against something, the fan noise is louder than the induction noise with the stock airbox until about 3500rpm (by then its approaching full boost on the stock turbo)
I'm undecided if I can live with it, I might just keep it for track days etc
Hmmm so significantly louder!! I might just leave mine off while its still getting street driven... Will see how it goes i guess! Are you sure its not locked up all the time? As if its running cool the hub should be free spinning and quiet i would have thought?
Thats what I'm trying to work out. I'm pretty sure its not locked up, as I can rev the engine and the fan speed only increases a little bit. I've got a spare hub that I know for sure isn't locked, however the bearing has a bit of play. If I get chance I'll swap them over and compare noise
mine does the same thing, quite loud, with no difference in how much the fan slips on the clutch. From reading threads about this on other forums, my understanding is the design of the nissan fan incorporates trying to minimize noise as well as move air volume, whereas the gktech fan is designed for moving maximum air and reducing drag, and not much concern given to the noise factor. Something about the tapering out to a thinner point at the tip of the fan, greatly reducing drag at higher rpm. Ass-dyno tells me it 'feels' better at higher rpm, but yeah quite roar-y driving around in traffic esp when cold.
do you feel the extra load on the engine with more pitch pushing more air/drag?
Other than the increased noise, the car seems to go just as well. I'll watch the economy to tell me if there is any extra load on the engine overall
Pulled it off over the weekend and put the stock fan back on.
The extra noise got pretty annoying, especially when driving on open/windy roads where you are on/off the throttle.
I'll chuck it on if I am going to do a track day, but for daily duties the stock one wins because of the lack of noise. My fan hub is working fine also.
Thanks for the update, good to know :)
  • 3 years later...
Ummm... Wow!
I was initially one of the guys complaining about these fans until i found that JEM had fit the damn thing backwards! So that made me look like a goose!
I have been spinning mine to over 8000rpm for long periods at the track and have had no issues at all and the cooling system has been spot on ever since.
You sure you didn't break an engine mount or something else as that sure looks like contact of some form? Ouch!
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
