so i got a R32 GTS and well as you can expect from a N/A RB20 its rather sluggish. ive got a turbo motor that i bought, it came with the intake, turbo, dump pipe, ECU and oil lines.
the plan is to clean the turbo motor up and swap the good bits from the na block and transfer to the turbo block.
i have a few questions on thing im not clear with:
1. where do i put the AFM
2. is there any other sensors other than the AFM, O2, CAS, TPS that the GTSt has that the GTS has such as pressure sensor etc.
3. do i need a bigger fuel pump and pressure reg
possibly many more questions coming
thanx guys
https://www.sau.com.au/forums/topic/436198-gts-to-gtst-conversion/
Cheaper to buy a gtst than convert a gts
You have the engine but it seems you havnt considered the brakes and the many other little things you need to make this a sucessfull conversion
Ok here is a step by step guide I wrote up a while ago:
1. Put your car on carsales.com.au
2. Sell your car
3. Buy a GTS-T
4. Go on a $4k holiday overseas with the money you saved
5. Proceed to drive your GTS-T which is worth more, less expensive and better than a GTS +T
  • Like 1
From memory, it goes under / behind the airbox.
So: Airbox > AFM > Intake Pipe > Turbo
This!
oh yeah, did them and the hubs already
mostly just want the engine stuff, not bothered about everything else
Considering your car will have more power then the N/A engine, there will be things that need replacing in order to handle the power upgrade.
You'd want to look out for the clutch.
A brake caliper upgrade to the GTS-T model would be a good start.
At least a 3" turbo back exhaust will help with the exhaust flow.
Did the RB20DET you bought come with the side mount intercooler and blow off valve?
It's just a start to the "To Do List" for this conversion.
I may be missing something, but if you have a turbo motor sitting there, why not jut put that in?
Sounds easier then changing bits over, not to mention the comp ratio will be right on the turbo motor
If the turbo engine is blown then disregard this :)
Okay, so I have the hubs, rotors and calliper a from a GTS t, along with the ecu and motor from one
In regard to the AFM, I have a custom intercooler, now do I put it after the intercooler in regards to pressure drop across the intercooler or am I seriously wrong
The bits I'm swapping is just vacuum lines, alt, power steer pump etc
Exhuast will be custom made, got a HD clutch waiting to go in and haven't got a BOV as I told I didn't need one as it will only ever run 7-12 psi
Air flow meter measures air flow (hence the name) so pressure makes no difference, a good example is you get a cylinder of compressed air, you blow up a massive air balloon with it, the baloon takes up an entire room at atmospheric pressure vs the cylinder taking up a small space with extremely high pressure, is there more air in the cylinder? Answer is no hence assuming the pressure drop from the IC isn't due to a leak you still have the same amount of air.
If it was a MAP (pressure) sensor, then yes it would matter as it doesn't measure airflow, it just infers airflow from pressure.
Edited by Rolls
will bov or recirc valve increase perfromance and stop damage in any way
also do i need a GTS-t fuel pump or will and GTS one suffice
Not sure if they are different or not, I would get a replacement for peace of mind though.
BOV won't do anything for performance or damage, purely to keep noise levels down and stop popping/richness on gear changes.
well the cars off the road for a while so ill try the GTS one for a while and see how it goes
okay no worries
If it doesn't work it might still run but just lean and blow your motor up. Only way to know if it is working is with a wideband in the exhaust, a dyno shop could check it for you, wouldn't cost much more to just buy a new pump though.
I wouldn't run an RB20DET with the original factory turbo fuel pump. They're so old now that they're just waiting to die. On that basis, using the original NA pump would only be as bad, if not worse.
Bite the bullet, put in the $200 Walbro now and be done with it. Save yourself the headkicking you'd have to give yourself if you don't change it and it fails.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
