So I got around to reading Go Auto news today (yes, it's not the most reputable publishing, but it gets emailed directly to me at work).
Turns out that a few days ago, Coles and Woolworths agreed to cease heavy discounts on fuel, as other companies were unable to compete as they did not have separate arms of business to draw the losses from. As a result, Coles and Woolworths have agreed to limit all discounts to 4 cents per litre.
I am absolutely astounded that, after all this time spent 'investigating' pump price cycle, price gauging, collusion, and generally having no correlation to Singapore oil prices (even if hedged months in advance), the ACCC have only succeeded in removing predictable price cycles (i.e. we knew Tuesday was the cheapest day to fill up, now it's russian roulette) and to now reduce the discounts that consumers get.
Further, these discount dockets only seemed to recover the amount that was artificially inflated by the scheme at the pumps - meaning the consumers have once again been left to bear the prices without protection.
I don't mind paying the taxes on fuel (45% or so) but I'm getting pretty tired of the manipulation of pump prices, and the lack of positive action by the ACCC/Fuel Commission.
Article link: http://www.goauto.com.au/mellor/mellor.nsf/story2/0280BC0B01715E58CA257C39002350B1
Well, I drove to one Shell on Monday night, $1.50/L for E10. Drove 5 minutes to another one, $1.44/L for E10. Filled up 95RON for $1.57/L (the latter Shell didn't have 98, was in my Mum's 2012 Corolla). The earlier Shell had 98 for $1.70/L.
Go figure.
While I was in the Netherlands, the price of petrol remained pretty consistent across the whole country.
What? They didn't take into consideration "transportation" costs? Lol. Silly them!
i used to bitch about the price of fuel, but these days i don't see the point. the profit margins in fuel is low compared to many other things (like bottled water). sure fuel will never be what it was 10 years ago, and it's silly to think it would be. inflation alone can be used to account for about 30c of the price difference from then to now. not to mention that it's still much cheaper than fuel in europe.
as for servos varying prices within a few minutes of each other, you have to take into account the running costs of the servos. ever seen rent prices of houses vary by large amounts even though they are only 5 minutes away in another suburb? well the same goes for commercial property.
but the servos i pass everyday don't fluctuate the way some do. some haven't changed their prices in weeks. others will vary by a cent or 2 maybe once a week. but i have seen some odd price differences between towns. i work in noosa and live in gympie, so i see prices in gympie, noosa and cooroy everyday. noosa and cooroy are generally similar in price. gympie will sometimes be the same, other times i've seen it vary by up to about 8c a litre. it will generally go in cycles that last a few months. so for a few months gympie may be 5c a litre cheaper, then there will be some price volatility and after that settles down gympie will be 5 or 6 cents more than noosa/cooroy (more being that noosa/cooroy will have dropped their prices and gympie has stayed somewhat the same). but there is one exception to all this. there is one servo in town that is currently about 10-12c a litre cheaper than every other servo in town, and has been for quite a while now. i had also heard rumours that there was also a servo in town whose bowsers were inaccurate by around 5% or so and it was thought to be that servo, which would roughly make up for the difference in price.
lol bottled water. Bottled water in Vietnam is 50 cents for a 1.5 litre bottle of La Vie, and that's not the cheapest price either.
Here it's just ridiculous. Must confess though, when I order food from a fast food joint I generally get a bottle of water as the drink cause I don't really like the 2 cents worth of fake coke they would otherwise sell you.
  • 3 weeks later...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
