Hi All,
Listed as below.....low ballers will get no response.
Car is for sale with all my spares bar a spare turbo and the V35 Rays rims. Just needs a new motor!! :P $11K
I wont breakup the items from there lists either:
  • Sway Bars + Front and rear brace - $500
  • BC Coilovers - $750
  • Nismo ECU - $1,250
  • R33 GTR 324mm Brembo callipers and DBA rotors with a near new set of Hawk pads and a half warn set - $650
  • Works Bell Paddle Shifter - $300
  • Complete Black interior - $1000
  • Greddy sonic POD - $150
  • Suction pipe to suit 30/71 BB in standard housings....needs spacer for bush core - $500
  • Mishimoto radiator - $200
  • HDI FMIC including fan - $320
  • Greddy oil cooler + Greddy thermo Sandwich plate + Sensor and output - $450
  • Z33 LSD - $450
  • 3.538 ration front diff(match's Z33 ratio) - $350
  • Greedy informeter - $250
  • Takero's Carbon Fibre rear wing - $400
  • Custom front bar to suit ARX or AXIS....needs repair and spray - $300
  • Nismo exhaust, Decat front pipe, dolphin front pipe - $1,000
  • 610cc injectors, Injector harness and plenum spacer - $500
  • HDI EBC - $100
  • Standard H/F Turbo 30/71 BB core with supporting mods for bolt on(Will need a service) - $700
  • gearbox with Shift kit - $300
More parts to come - I'll take photo's of some of the items. PM me for more detail....don't be offended if I don't respond to low ballers!
All parts are in Sydney......Please note that some of the parts may take some time to get off the car.
cheers
Craig
Any idea what postage would cost to Adelaide for (or if you're even interested in posting them):
Greddy informeter
So much more i'd love to buy.... funds too low though (that black interior would be a huge step up from the horrible tan i have now)
Cheers
Cam
Greddy informeter
Cheers
Cam
I'll post.....it will be under $100 via ego.
  • Sway Bars + Front and rear brace - $500 - SOLD
  • Nismo ECU - $1,250 - SOLD
  • R33 GTR 324mm Brembo callipers and DBA rotors with a near new set of Hawk pads and a half warn set - $650 - SOLD
  • Greddy sonic POD - $150 - SOLD
  • Suction pipe to suit 30/71 BB in standard housings....needs spacer for bush core - $500 - SOLD
  • Mishimoto radiator - $200 - SOLD
  • HDI FMIC including fan - $320 - SOLD
  • Z33 LSD - $450
  • Greedy informeter - $250 - SOLD
  • 610cc injectors, Injector harness and plenum spacer - $500 - SOLD
  • HDI EBC - $100
Update
  • Works Bell Paddle Shifter - $300 - SOLD
  • Complete Black interior - $600
  • Z33 LSD - $450
  • Nismo exhaust, Decat front pipe, dolphin front pipe - $1,000 - SOLD
  • HDI EBC - $100
  • Like 1
I send that kind of stuff Auspost; it will come in under 100cm, and under 20kg.
Estimate will be around $30ish. ;)
Hey Craig,
I dont suppose you've got a harness adapter that is pre-pinned for an E-Manage Ultimate lying around as a result of your R&D efforts do you?
Haha, pre-pinned harness adapter?
They are all hard wired to the oem loom. How many do you think we have tuned so far Dunc? :P
Perhaps you could swap the entire harness, it isn't too hard. Much easier to cut yours up and wire in the universal harness though.
Couldn't remember if there was a 'small' harness between the full loom and ECU - figured it wouldn't hurt to ask :P
I have got a spare engine harness I bought a while back that does have the E-manage cut into it. I paid $100 for it if you want it.
P.S. You will still need to sort the EMU side though.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
