We've got an R33 GTST, with an almost stock RB25DET. Only mods at this stage are a cat-back 3" exhaust, an R34 SMIC, and the 7psi boost solenoid mod. We have replaced all fluids & filters, timing belt & bearings, front & rear seals, water pump, & spark plugs (copper gapped to 0.8). We've found & fixed a few boost leaks & it seems to be running sweetly.
The car is registered, but will be used almost exclusively as a track car - doing hillclimbs, track days / supersprints at Malalla, and motorkhana / gymkhana type events. We don't want massive power (yet) but are looking for lots of torque with no lag & good response.
We are starting to gather bits to get it tuned, and deciding which way to go. Budget is a bit limited at the moment, so it will be a 2 (or more) stage process. So far we have a Z32 ECU with Nistune installed and a Z32 AFM, but neither are installed. We also have a Hicas lock bar to be fitted this weekend.
We are debating whether to do an injector upgrade (for E85 conversion) or a turbo upgrade (probably highflow the stock one) before the first tune - it will only be one or the other. Whichever one we don't do now will happen sometime late next year.
We will upgrade the fuel pump before doing anything, just to be safe. The first question then is what fuel pump should we be buying to support E85 and a highflowed turbo)?
We have a Blitz SBC boost controller (came in another car & doesn't need it). We aren't sure if it will be any use in the R33 with a Nistune ECU, and we are considering selling it to help fund the upgrades & tune. So the second question is should we keep the EBC or sell it - is it of any use to us?
An associated question is how does the stock boost solenoid work, and how does a Nistune control it to adjust boost (if at all)? Is the solenoid an on / off device, or is it pulsed to vary boost bleedoff?
Last question (for now anyway) is which way would you go first - E85 or highflowed turbo - and why? Costs are similar - around $800 for a set of ID1000 injectors with fuel rail & reg, and around $1000 to highflow the turbo. I'd expect power results to be similar.
For anyone starting to type "search the forum - it's all been discussed..." I have searched, and read a shit-load of posts (and conflicting opinions). I'm trying to tie it all together. Looking for constructive input.
Search the forum It's all been discussed.
But..... E85 on its own - useless. The stock turbo can't be run to high enough boost to make sufficient use of the extra knock resistance of the fuel. So get Stao's latest R33 highflow job done + 3" metal turbo intake.
Stock boost solenoid is simply a "low boost"/"high boost" switch and therefore effectively useless, even with Nistune. Throw it away, fit a proper boost controller. Do not use more than about 12-13 psi on the stock turbo for fear of destroying it.
Do not wind up the boost too far even with the highflow turbo fitted, because the stock injectors are only good for maybe 220rwkW. Maybe more, maybe less.
Buy the Walbro E85 fuel pump.
  • Like 1
Hi, I count not more highly recommend a HKS GT-RS turbo kit for the RB25det. Its my favourite turbo by far - very responsive, plenty of power, not too expensive, quality Japanese system, bolt on kit, neat, the list goes on. Well spent money!
The path to power can be expensive and you might find yourself spending twice or three times on specific components unless well thought out.
Common question - identify your power/performance target. That's going to dictate what bits are needed, and the various supporting components.
Sub 300hp/225kW and things are relatively easy, plus the car will be more useable for a number of your planned disciplines.
GTS Boy is on the money. Up to that point, forget injectors. Do the pump and direct wiring mod though. Go for Hypergear turbo, run on pump 98, that will get you a decent upgrade for much cheaper than a GTRS kit. Then start putting money aside for a decent clutch.
If the goal is going to be 350+ hp, just do a clutch straight up and keep putting money away for an inevitably bigger turbo than highflow, plus pump, wiring mod, and injectors. At that point you would just size for E85 flow capable units, and make a decision about whether you want to burn alcohol and tune to suit.
280-300hp is relatively finance-friendly, surprisingly quick, and useable power. There are a couple of good threads about where guys have focused on suspension/steering/brakes/tyres/diff but stayed with near stock power. Much smarter move, wish I had gone that path a few years back and left engine upgrades to later on the list.
No point having oodles of power when it's just frying tyres and spinning off the track.. second time round with the shit box and so far it has been all handling mods, it still runs the stock turbo (for the next few weeks lol).
I'm sure a properly setup R33 with only 200kW from a stock turbo will run 1m10s around Wakefield park easily, than something that has 300kW+ with just your run of the mill ling long coilovers
Fit the boost controller and Nistune and run 10psi. Then as above spend money on suspension, tyres brakes and time making the car lighter. A guy over here has been developing a street legal track car and is doing good times with the stock turbo after concentrating on brakes and handling and making the car lighter.
I'd go a Hypergear highflow with Nistune. One of the moderate high-flow options with internal gate. You'll need the Blitz SBC - it is a good boost controller. Nistune does NOT control boost.
What power level do you want. There are pros and cons with bigger turbos. Something around 240-250rwkw is pretty sweet.
E85 adds very close to 10% of power and some response. Up to you if you think it's worth the extra tuning cost/larger injectors, reduced range (300km per tank) and reduced number of fill-up spots.
I've got ~235wkw from:
AX53B70 turbo
Nistune
Blitz ID3 boost controller
S15 injectors
FMIC, dump/exhaust, big 100 cell cat, etc
all suspension done, some bushes, strut mount, etc
595RSR tyres
A GREAT daily but f I did it again now I'd probably start with a GT30 0.82 internal gate and E85 with bigger injectors and good local coilovers. BUT that's because I have another car as a daily.
Edited by simpletool
I think just about anything can crack a 1'10 @ wakie with a bit of practice and a good set of tyres..
the only time an r33 needs a heap of suspension mods is when they have big power to put down and traction is an issue...A low power say 200-220kw r33 doesn't need much more than some decent coilovers and good brakes/tyres to run fast...
Get coilovers, replace all the bushes, buy front castor rods, rear camber arms, install a HICAS lock bar, fit subframes bushes, get a 1/1.5/2way LSD, get a bucket seat..
Beats the hell out of loads of power.
  • Like 1
See the only mods i have is some bilsteins shocks, braided brake lines, good fluid, a hicas lock bar and some wornout old r-spec dunlops...yep that's it.stock bushes ,stock arms,stock diff and stock brakes
.Its not ideal but I Reckon I could of easy got a 1:10 with a little more practice, i got 1:15 or something on like my second lap out before going off the main straight and being chicken shit cause I needed the car to drive me home..
oh yeah I have 300kws too...
Nothing beats a whole Lot of power. ;)
Though I do agree with you its not needed for good times ,especially at wakie...but power is just so easily attainable on a 33...I dont think alot of suspension mods are needed either ,if you are on a budget weight reduction and good semi slick tyres is a great place to start
But to each his own and more than one way to skin a cat and all that.
+1 for this.
if you are considering E85 in the future then this is the pump for you. The 255 is okay but if you switch to e85 on a highflow you will need the big pump.
as far as turbo or injector upgrade. I would actually suggest saving a bit longer and doing both. A hypergear hiflow or a brand new turbo from hypergear + a set of injectors and a fuel pump before tuning that nistune ECU along with the Z32 AFM and a metal intake pipe will net you a very responsive 300rwkw +. If this is too much power for you simply turn boost down a bit. The JECS highflowed injectors from FIVEO will do the trick, they are pretty average injectors and I'm not really happy with them for street use but they will be fine for a mostly track car.
This is expensive, but cheaper than tuning more than once.
edit: didn't realise you still need a FMIC and turbo back 3" minimum to fully maximise a new turbo
Edited by Blackkers
my honest opinion to you would be to get a high flow turbo and a set if injectors and tune the car properly with the ecu and boost controller that you currently have.
you cannot use the stock solinoid, they can be used on a aftermarket ecu but not with a nistune but you have your aftermarket boost controller available anyway.
e85 is not going to do you much good this early imho.
I suggest a set of 740cc + injectors so LATER you can always do the switch to e85 without replacing them.
Doing the highflow and injector upgrade (make sure the fuel pump is good enough, a walbro 255lph should be enough) should net you around 250kw at the wheels which is a decent amount of power and lots of room to improve if you go to e85 later if it is required.
you CAN skip the injector upgrade and tune the car to around 230 235 rwkw which might be all you are looking for anyway?
I would go for this option because you will get more power with a high flow on pump gas then you will with a stock turbo on e85, also the stock turbo on r33's are getting pretty old these days and it could grenade at any time.
good luck
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
