How To Get Rid Of Sluggish Coldstart/warmup And Bad Fuel Economy On Your Nistuned Rb20Det/z32/gtr Ecu.
  • 1 month later...
Who knows then!
Hey rolls quick question about this
Can you make these changes via a trail version of nistune?
I don't want to pay a workshop in ACT to make these small changes because I'm sure they will try charge an arm and a leg and DVS lives too far away for something this small
Pretty sure they don't make a trial version of nistune anymore, you should email pete/matt and say this is the only change you want to make, they might be able to help you out or point you in the direction of someone who can do it for basically free, they are both good blokes so I'm sure they will at least suggest something.
If they do have a trial version, let us all know!
http://www.nistune.com/contact.php
Edited by Rolls
That's a shame that people do that Matt.
As it would take literally 5minutes, perhaps your tuner could make the changes for free or cheap as Manuel Kasko, especially as you are bringing in a bit if knowledge for them to help future customers.
Edited by superben
Spoke to Nistune which I guess is Matt above haha.
Too many dodge people have wrecked it for us.
I'm going to wait for my 34 to pass compliance, then I will pull the ECU out of the 33 and send it to Matt to get sorted.
Tuner is about 4 hours drive from here.
ACT Nistune tuners will probably charge me too much for the changes.
Changes are disabled in the trial now, because some people would tune customers cars using the trial version!
If people are so cheap they won't spend the $200 to get a personal license (even though they should get a tuners license) then I doubt getting rid of the trial version will stop them, they will probably just steal someone elses license code or get 20 people to chip in and do that.
Do you have checks in the software to stop people sharing license keys?
Why not give a tuner a call? explain exactly what you want them to do, surely they wont charge you more than $20 for a 5 minute job.
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
