Rotors are the same part number (if you have ventilated rear rotors), calipers are the same too, they both use 2 piston sumitomo calipers, so looks like it should be good to go.
Ok I'll have a crack tomorrow and see what happens, thanks for the input!
As silly as this may sound to all/most of you - does anyone know of a thinner
rotor and caliper that will bolt straight on.. For example r32 non turbo rear brakes or r33 non turbo rear brakes, both drilled to 5 stud?
If anyone knows if these or something else smaller than stock will fit without modification I am keen to know :)
Thanks!
R32 GTST including R32 GTR should be 297mm diameter X 18mm thick ventilated rears.
Next down is a 266 X 16 ventilated rear thats hard to find after market....same 5 bolt stud pattern.
In those cases we have been telling customers to send the larger ones to a engineer to have the outer diameter turned down and 2 mm skimmed off them.
Next down is 266mm X 9mm solid, but its 4 bolt stud pattern....
Not sure what calipers they are, the part number for the pads is different, they are not the Sumitomos that the turbo models use with the 2 pins passing through the pads to hold them in.
I have seen a few customers cars come in with them, i think from memory they are only a inboard single piston job, my brake catalog says R33 Non Turbo so i would be looking that way, they are probably a lower level of Sumitomo in single piston.
Concentrate on anything with 4 stud wheels from the R32, R33 range in non turbo is your best bet.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
