I'm not sure how much detail you can see but there are large shavings of metal on the plug itself. I'm planning to pull the diff and throw a shim in there today. Looks like my diff centre has taken a beating.
I've got a single 0.8mm shim which I'm thinking won't be enough if the gears are quite worn.
any thoughts or suggestions would be greatly appreciated, thanks
never in my ownership but that's only since June.
The oil itself was okay, bit low maybe 1.2-1.4 liters in total (should be 1.7 according to the manual)
I'm throwing another shim in there, its possible that it has extra shims already which caused extra wear. I'll find out once the thing is apart.
on a side note; having a rattle gun saves a lot of swearing!
Some times the oil is very rarely changed in diffs and can still look ok but that mag plug did its job at least and yeah owning a skyline usually involves swearing so anything to reduce it is good, my latest anti swear device was a hoist almost too easy now
Diff is 100% undisturbed, never opened and the shims are factory. I'm not worried if I have to bin this one after a year or 2.
anyway I'm going to grab a 2nd shim to throw in there seeing as the diff itself is quite worn. The gears in the diff center are visibly worn so I'm swapping out the factory 0.8mm shim with a 1.2mm + adding a fresh 0.8mm (increase of 1.2mm preloading)
Diff is all back together, wasn't easy to reinstall on the ground. needed a mate to help move the jack around
It definitely has that new shim feeling. wheels hopping in tight corners etc. feels pretty well locked as far as I can tell :D
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
