I'm not sure how much detail you can see but there are large shavings of metal on the plug itself. I'm planning to pull the diff and throw a shim in there today. Looks like my diff centre has taken a beating.
I've got a single 0.8mm shim which I'm thinking won't be enough if the gears are quite worn.
any thoughts or suggestions would be greatly appreciated, thanks
never in my ownership but that's only since June.
The oil itself was okay, bit low maybe 1.2-1.4 liters in total (should be 1.7 according to the manual)
I'm throwing another shim in there, its possible that it has extra shims already which caused extra wear. I'll find out once the thing is apart.
on a side note; having a rattle gun saves a lot of swearing!
Some times the oil is very rarely changed in diffs and can still look ok but that mag plug did its job at least and yeah owning a skyline usually involves swearing so anything to reduce it is good, my latest anti swear device was a hoist almost too easy now
Diff is 100% undisturbed, never opened and the shims are factory. I'm not worried if I have to bin this one after a year or 2.
anyway I'm going to grab a 2nd shim to throw in there seeing as the diff itself is quite worn. The gears in the diff center are visibly worn so I'm swapping out the factory 0.8mm shim with a 1.2mm + adding a fresh 0.8mm (increase of 1.2mm preloading)
Diff is all back together, wasn't easy to reinstall on the ground. needed a mate to help move the jack around
It definitely has that new shim feeling. wheels hopping in tight corners etc. feels pretty well locked as far as I can tell :D
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
