Do series 2 stagea come stock with Keyless entry? im not so sure as my car was imported and wasnt sure if the previous owner had them installed or thats how the car was made , also is their any other way to get a spare remote for these type of keyless entry cars as i want to get a spare since i only have one remote and key
Series 1 have them too. They are certainly a factory item but don't know if they all had them or were an option. You can buy another key from Nissan but someone may be able to supply a suitable blank in which case there are programming instructions on this site.
  • Like 1
Another option is to go for an aftermarket alarm and immobiliser. Its a pretty good investment, and you'll get a new remote. Then just buy a key blank like this and get any key cutter to duplicate your existing key. Its much more attractive than the standard key
  • Like 1
I agree, I did that with mine (went aftermarket) as
1) we wanted three sets of keys and remotes anyway and
2) it drives me insane (or more so :-)..) when the windows don't wind themselves up when you lock the car (had it like that for too many years..). With an aftermarket alarm you just wire up the windows and they all go up when you hit the button to lock the car.. :-)
Ian
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
