http://www.skylinesaustralia.com/forums/sh...ead.php?t=43555
I have said it many times before...do not even contemplate taking your GTR onto the track if it doesn't have a proper baffle in it. People in this thread have punched a hole in their blocks or spun bearings.
It is not a very expensive thing to do but will save your engine. If you want to do a track day in your GTR, please do up your sump first. Oil cooler is necessary, but will not stop your oil from surging.
https://www.sau.com.au/forums/topic/43640-gtr-owners-read-this/
Yes, The R won't be seeing any real action till it has new sump with baffles, large capacity oil pump, oil cooler, bigger radiator, oil restrictors, enlarged oil return galleries and catch-can. So by about the year 2010 I think I should be ready.
Apparently the engine has to come out to take the sump off. Does anyone know what it is worth to fit baffles??
you forgotten exhaust, dump pipe. new turbos, big FMIC, 6 pots brakes, etc ,etc :D
To baffle your sump i think it costs around 200-300 done by the mechanic i use. You might find someone to do it for cheaper.
My Trust sump set up was cheap, but that's because I'm a dodgy Asian. I did not do the sump myself as I do not have an engine hoist nor do I have an angle grinder and a welder. Alternatively, you can buy a ready made JUN sump (not the parts to baffle the sump) for about 3 times what I paid for the Trust item.
I have said it many times, engine revs or how many laps are not important. How hard you turn is the important factor. QR has 3 right hand turns alone after the main straight, consider how much the oil would have moved to the left. Then think of the starved engine being revved to pull the car through turn 3 and bang you have a hole in your block.
So far, my mechanic has handed out accurate and invaluable advice to me, although it doesn't come cheap, although his advice regarding the sump was:
"Some people have gotten away without a sump for a couple of track days, but it's a $10k risk you are taking. If you're unlucky, your engine will blow by turn 2."
I don't know where people got the impression that GTRs are track ready from factory. They're far from it. They're a road going homologation of a race car, except the N1s or the special edition GTRs.
You have no idea how many times I thought I have prepared my car for the track only to be told this this this needs to be changed first. Not a cheap hobby nor car to choose for the track.
On a side note, Sydneykid has explained why the GTRs experience higher oil temps, i.e. 2 turbos and mainly because the front diff runs through the sump.
Hey rb26dett, who is your mechanic? $200-300 sounds bloody cheap. I NEED to get mine done ASAP and am currently trying to get some pricing.
Thanks
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
