R33 Gts-T Series 2 / Knock Knock Who's There ^_^ 33 Rebuilding
Hey guys please enlighten me there are so many things scattered throughout SAU about engine rebuilds and bottom end bearings failing but they all seem to end in people arguing about whose kettle is better than their toaster and mass amounts of cursing haha :domokun:
Vehicle: Nissan Skyline R33 GTS-T Series 2 (96)
ODO: 130,000
Modifications:
FMIC
Splitfire packs
Apexi pod filter with cold air intake
Full 3" exhaust with hi flo woven cat and split dump and resonator removed
Stock turbo running 14psi@185kw with turbosmart boost tee
Apexi power fc tuned today (Thanks chiptorque!)
Apart from that things are pretty much stock until my bank account says so otherwise haha :worship:
Anyway the matter of the topic is that i just had the power fc installed today and the boost wound up a little but apparently the tuner can hear some bottom end bearing noise which i cannot hear but apparently is there. I am yet to have any knock checked properly with the right equipment just to be sure of any problems
My 3 options are
New engine
Motor rebuild
or fetch me a prius and some AA batteries :rofl2:
Im not liking the idea of a new motor especially when 95% of them are second hand and if you can find a new one then you will have to start chopping limbs off to afford them ha
For now i have my mindset on a rebuild but i have never come to the stage of needing to rebuild a motor on any of my cars now i have heard of rebuild kits such as this one http://www.spoolimports.com/spool-engine-rebuild-kits/nissan-rb25det-rebuild-kit
The kit consists of
  • SPOOL Forged H Beam Conrods
  • CP or Ross Forged Pistons (Rings, Pins and Locks Included)
  • Cometic MLS Head Gasket
  • ACL Race Series Main Bearings - STD & 0.25mm
  • ACL Race Series Big End Bearings - STD & 0.25mm
So the question is.. Is a rebuild kit like the one above going to solve my problems? yes it a pricey process but hey thats the 4 wheeled money pot i guess :banana:
Anyone with some helpful advice i would greatly appreciated :cheers:
Who are you getting your second check from if you don't mind me asking?
Redline EFI its the mechanic i always use never had dramas with them and always do what needs doing properly first time every time
So i just took the car to have the noise checked out using a piece of equipment which im unsure of the technical term for it as i have never seen or used one but it was a snap on amplifier that connected to different sections throughout the motor using about 6 or 8 clamps that were clipped onto the turbo engine mounts manifold etc and you put a set of headphones on and had a listen and good news it was top end noise and cam bearings was the big bad wolf so its safe to say im happy with that as the bottom end was almost silent as a pose to the cam noise :worship:
Anyway now the problem has been pinpointed tomie poncams and tomei cam gear are sounding like the goods and of course cam bearings but the question is where can i get cam bearings for an RB25DET i know tomei poncams and gears are not hard to come by just wanted to check in with people on the forum as to whether tomei poncams and gears are the go and also where to find camshaft bearings
Cheers guys! :thumbsup:
If you aren't planning on making too much power in the future I'd just leave the standard cams. I'm not too sure if cam gears are a benefit with RB25's. A couple of minutes research on here should tell you that though.
I'd just take the head to a recondition joint that you trust and have them go over it. It will cost a bit though. Depending on what needs to be done it's generally around the $1000 mark.
i do plan on making bigger power further down the track but im big on making sure the engine has good starting grounds before it starts having mass amounts of power thrown through it..
if they are changing bearings it wouldnt hurt to throw a set of poncams in while theyre at it because i have seen some good things about them not neccessarily power gains but the way the power delivers itself through the rev range etc..
Question is though what type of poncams do i get there types with certain lift etc.. but i dont want to have that all adjusted and worry about valve springs and stuff i just want a drop in set
oh cars why u do this!
Cheers gents
I'm not too certain about RB25 heads but if you stick with the smaller sized poncams you can retain the standard valve gear if it is in good nick.
I'd be having a bit of a read through the RB25 threads and see what head work will suit your goal.
And as you plan on making big power, I wouldn't do it with that engine. Cam wear is a sign of neglect. Might as well thrash it while saving for a full rebuild or throw in a good nic neo.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
