I have a r33 gts-t at the moment and yes i want to make it a rb25de.
I have just found out that i have blown the head gasket, so i was just wondering if anyone would know if i can shave the head and run a thin head gasket to get the comp to at least 10:5:1 at least.
I have a powerfc wired up to my stock 25det loom already so thats why i was just gonna make this motor a DE.
thanks
https://www.sau.com.au/forums/topic/436421-rb25det-to-rb25de/
Prob a lot easier and cheaper to sell the motor as a det and buy a neo n/a motor, I wouldn't bother getting anything machined.
It can be done though, don't see why not, there should be a lot of different thickness head gaskets available for the rb25, just don't go crazy skimming the head, don't want to take to much off.
Its just would be better for me to keeep the det as i have a pfc already wired up to it. so i save money there.
I was just worried about clearences when i shave the head and run a thinner gasket and if it would make an issue?
By the time you're done what you're planning, you could have thrown an N/A NEO6 in there for less. I've seen good RB25DE's go for $500.
Cost vs. time. Remember that machining work and parts will cost you $1k easily. Pretty sure that you'll have to change the pistons to get it to the 10:1 mark.
these threads don't get locked on sight?
TL;DR, engine is incredibly low comp for N/A use, would need to be retuned, still run like shit, and depending on the state, still be illegal. Put N/A motor in or don't drive / sell / use as track car while on P's. Conversion has been done before, with the above mentioned results.
MBS206: you mean upgrade there pal
^^what a load of misinformed dribble, 9.0 to 1 isnt by any means "incredibly low comp" , it will run fine after a retune and it will be okay to run 91 ULP and wont run like shit at all
Been done before, runs like shit.
It's not just comp that's different, but cam profiles etc etc.
^^ yes I already know that it would need a retune (ive also agreed above on that point) 9.0 to 1 is plenty high enough for a na 2.5 litre and most other engines with efficient 4 valve and dohc designs heads. .engines can be de+t and det-t...
Im not arguing that its a waste of money. . . My point is that its achevable /doable
How will different cam profiles make it run like shit?
Cam profiles are designed pending certain applications, youll be completely changing how the exhaust flows and therefrore how the head and cams will breathe.
Kind of like shoving huge overlap cams in a V8 and then bitching the car wont idle like standard...
the engine is designed as one large system, that youre f**king with. It will drive, itll also make way less power than an RB25DE from the factory. There is a reason so many people have complained about driveability after doing this exact conversion...
^^hmm google must have it wrong then because it shows the cam profiles between the r33 rb25det and r33 rb25de are the same - 240 degrees duration and 7.8 mm lift on both inlet and exhaust
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
