I have a r33 gts-t at the moment and yes i want to make it a rb25de.
I have just found out that i have blown the head gasket, so i was just wondering if anyone would know if i can shave the head and run a thin head gasket to get the comp to at least 10:5:1 at least.
I have a powerfc wired up to my stock 25det loom already so thats why i was just gonna make this motor a DE.
thanks
https://www.sau.com.au/forums/topic/436421-rb25det-to-rb25de/
Prob a lot easier and cheaper to sell the motor as a det and buy a neo n/a motor, I wouldn't bother getting anything machined.
It can be done though, don't see why not, there should be a lot of different thickness head gaskets available for the rb25, just don't go crazy skimming the head, don't want to take to much off.
Its just would be better for me to keeep the det as i have a pfc already wired up to it. so i save money there.
I was just worried about clearences when i shave the head and run a thinner gasket and if it would make an issue?
By the time you're done what you're planning, you could have thrown an N/A NEO6 in there for less. I've seen good RB25DE's go for $500.
Cost vs. time. Remember that machining work and parts will cost you $1k easily. Pretty sure that you'll have to change the pistons to get it to the 10:1 mark.
these threads don't get locked on sight?
TL;DR, engine is incredibly low comp for N/A use, would need to be retuned, still run like shit, and depending on the state, still be illegal. Put N/A motor in or don't drive / sell / use as track car while on P's. Conversion has been done before, with the above mentioned results.
MBS206: you mean upgrade there pal
^^what a load of misinformed dribble, 9.0 to 1 isnt by any means "incredibly low comp" , it will run fine after a retune and it will be okay to run 91 ULP and wont run like shit at all
Been done before, runs like shit.
It's not just comp that's different, but cam profiles etc etc.
^^ yes I already know that it would need a retune (ive also agreed above on that point) 9.0 to 1 is plenty high enough for a na 2.5 litre and most other engines with efficient 4 valve and dohc designs heads. .engines can be de+t and det-t...
Im not arguing that its a waste of money. . . My point is that its achevable /doable
How will different cam profiles make it run like shit?
Cam profiles are designed pending certain applications, youll be completely changing how the exhaust flows and therefrore how the head and cams will breathe.
Kind of like shoving huge overlap cams in a V8 and then bitching the car wont idle like standard...
the engine is designed as one large system, that youre f**king with. It will drive, itll also make way less power than an RB25DE from the factory. There is a reason so many people have complained about driveability after doing this exact conversion...
^^hmm google must have it wrong then because it shows the cam profiles between the r33 rb25det and r33 rb25de are the same - 240 degrees duration and 7.8 mm lift on both inlet and exhaust
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
