I have a r33 gts-t at the moment and yes i want to make it a rb25de.
I have just found out that i have blown the head gasket, so i was just wondering if anyone would know if i can shave the head and run a thin head gasket to get the comp to at least 10:5:1 at least.
I have a powerfc wired up to my stock 25det loom already so thats why i was just gonna make this motor a DE.
thanks
https://www.sau.com.au/forums/topic/436421-rb25det-to-rb25de/
Prob a lot easier and cheaper to sell the motor as a det and buy a neo n/a motor, I wouldn't bother getting anything machined.
It can be done though, don't see why not, there should be a lot of different thickness head gaskets available for the rb25, just don't go crazy skimming the head, don't want to take to much off.
Its just would be better for me to keeep the det as i have a pfc already wired up to it. so i save money there.
I was just worried about clearences when i shave the head and run a thinner gasket and if it would make an issue?
By the time you're done what you're planning, you could have thrown an N/A NEO6 in there for less. I've seen good RB25DE's go for $500.
Cost vs. time. Remember that machining work and parts will cost you $1k easily. Pretty sure that you'll have to change the pistons to get it to the 10:1 mark.
these threads don't get locked on sight?
TL;DR, engine is incredibly low comp for N/A use, would need to be retuned, still run like shit, and depending on the state, still be illegal. Put N/A motor in or don't drive / sell / use as track car while on P's. Conversion has been done before, with the above mentioned results.
MBS206: you mean upgrade there pal
^^what a load of misinformed dribble, 9.0 to 1 isnt by any means "incredibly low comp" , it will run fine after a retune and it will be okay to run 91 ULP and wont run like shit at all
Been done before, runs like shit.
It's not just comp that's different, but cam profiles etc etc.
^^ yes I already know that it would need a retune (ive also agreed above on that point) 9.0 to 1 is plenty high enough for a na 2.5 litre and most other engines with efficient 4 valve and dohc designs heads. .engines can be de+t and det-t...
Im not arguing that its a waste of money. . . My point is that its achevable /doable
How will different cam profiles make it run like shit?
Cam profiles are designed pending certain applications, youll be completely changing how the exhaust flows and therefrore how the head and cams will breathe.
Kind of like shoving huge overlap cams in a V8 and then bitching the car wont idle like standard...
the engine is designed as one large system, that youre f**king with. It will drive, itll also make way less power than an RB25DE from the factory. There is a reason so many people have complained about driveability after doing this exact conversion...
^^hmm google must have it wrong then because it shows the cam profiles between the r33 rb25det and r33 rb25de are the same - 240 degrees duration and 7.8 mm lift on both inlet and exhaust
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
