Awesome, this has made my week.
I actually rang Shannons yesterday regarding this before I saw this thread and I was told I would save approx. $400/y on insurance alone if the car had club reg.
I was just about to send of application forms to Classic Skylines Australia because I thought club reg. may never happen through SAU, this is great news since I'd still be be much happier doing club events with SAU.
Can someone please clarify if the 25 year rule takes the build date into consideration?
If so, where is the build plate that states what month the car was built? I've got two plates I can find in my engine bay that, one silver tag with '609000HCR32066791'
the other blue plate says:
E-HCR32
HCR32-066791
RCR32GFSM GC
KG1 G
RB20DET 1998 cc
FS5W71C RC43
Not sure if any of this info refers to the build month.
Also,
Lets just say that someone with a 25yo skyline has had an RB25 conversion with all supporting upgrades that hasn't been engineered yet, but otherwise the car is in near perfect roadworthy condition (needs new rear discs), could it be put on club reg. without engineers certificate if it passes everything else?
Apologies if this has already been answered before in another thread?
Cheers,
Rob
25 year rule is meant to take build into consideration.
so from your VIN
July 1990
so 18 months till worry about.
engine swaps are technically allowed
however you need to show it is done well, all the brakes and such is done and the car is safe.
If a car is modified, VIC Roads may ask for a VASS certificate. Not sure if they actually enforce it though
so from your VIN
July 1990
Dang..
Thanks for looking that up for me Martin, I had no idea. For some reason I thought it was built earlier and something dodgy had been done to comply it as a 90 when I brought it in.
Everything else is above board with the car, pretty confident car would pass a roadworthy with new rear discs as long as height adjustable coil-overs are ok.
thanks Tony, I guess with 18months to wait there will be plenty of people that will test the water before my car is eligible.
Someone over at aus300zx just had his 89' club rego'd and the rules seem to be for imports it's only the year of manufacture that counts as they have no way of confirming the build date. Therefore come Jan 1 of your year you can get in
You can drive all day everyday if you like but only for 45 - 90 days a year. Depending on the permit you purchase.
If you are driving past midnight you just need to fill in the log book for the next day.
Ah ok, thanks for that.
this is good news...1 year to go can i club reg my cressi or is it skylines only?...then if i hang onto the skyline for 4 more years..:P
so sick of paying 700$ a year for a car that gets driven a handful of times...
Is there a limit on the amount of cars I could have under club reg?
So according to what people are saying here I can put a ls1 or rb25/6 in r32 or or s13 but dont need a engineer/vass certificate aslong as its a clean properly done setup? How about emmissions?
Dosnt vicroads say u need a eng certificate for major modifications?
Classic and historic
– manufactured after 31 December 1930, but more than 25 years before the date of the application for a club permit; or
Street rod
– manufactured more than 25 years before the date of application for a club permit and modified in excess of the guidelines contained within the Vehicle Standards Information
No. 8 (VSI8),
Guide to Modifications for Motor Vehicles
Modified vehicles should really be on Street rod plates , Original or close to original vehicles should be on Historic plates.
Suspension or Cancellation of Permit
VicRoads may suspend a club permit if it reasonably suspects that
a) the vehicle operated under the club permit is not an eligible vehicle; or
b) the permit holder is failing to comply with any of the conditions of the club permit; or
c) the permit holder has disposed of a vehicle and has not destroyed the club permit label and the vehicle's log book and removed the number plates
d) the permit holder is engaging in conduct which threatens public safety or undermines the integrity of the club permit scheme.
Not only does this effect the person and the car that is caught doing the wrong thing, it will also come down on the club/ safety inspector if the club doesn't require RWC for club reg.
Refer club permit application form:
http://www.vicroads.vic.gov.au/NR/rdonlyres/4BC78D16-7C1D-4DCC-B0E7-A3932C2FD2DF/0/ClubPermitApplicationFeb2011.pdf
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
