Please text message if your interested
R33 gtst complete rolling shell minus rear shafts motor box. Has complete interior headlights gaurds bonnet etc byo wheels $1000
Rb25det s2 engine $1000
Rb25det gearbox $1000
R33 manual conversion kit $1350
R33 bonnet $100
R33 front brakes calipers and rotors $200
Many other parts available
R32 gtr bare rolling shell $2500
R32 Gtr bonnet mint $550
R32 Gtr gearbox $500
R32 gtr alloy gaurds $250 each
R32 gtr rear seats $100
R32 gtr boot and wing $200
R32 gtr headlights $200
R32 gtr side skirts $500
R32 gtr grill $200 mint!
R32 gtr diff $250
R32 gtr rear drive shafts $100 each
R32 gtr bilstein coilovers damper adjustable $250
R32 gtr bonnet latch $70
R32 gtr abs module $200
Hks gt2530 turbos good condition $1500
Greddy t517z turbos good condition $1800
R34 gtr ball bearing turbos comes as complete turbo kit $350
R32 gtr 3 inch cat back exhaust $300
Many other parts available from the gtr
R34 gtr passenger door bayside blue $50
R34 gtt drivers door with glass etc white $50
R34 gtt door cards $40 each
R34 gtr drivers window switch $50
R34 rear parcel shelf $40
R34 gtt front seats $90
R34 gtt sedan rear seat $70
R34 abs $50
R34 xenon passenger headlight mint $300
R34 drivers guard slight dent $30
Haltech e11v2 to suit r34 neo $750
Gold Coast
0487924497
  • Like 1
  • 1 month later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
