Turbo guru's, do you think this would fit it?
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-Garrett-GT3071R-GT2835-A-R-73-10cm-56-5mm-Trim84/291020897812?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D261%26meid%3D3436767607632936440%26pid%3D100005%26prg%3D1088%26rk%3D2%26rkt%3D5%26sd%3D291034391697%26
Or even this one?
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-Garrett-GT3071R-GT2835-56-5mm-Trim-84-A-R-61-8cm-T3-/291034391697?pt=AU_Car_Parts_Accessories&hash=item43c3006491
As far as i know the HKS gt2835 has these specs
TURBINE:
-Wheel- 84 Trim - 56.5 Major / 51.8 Exducer
-Housing- T3 inlet / Outlet spec:
-0.68 AR (Mine is 0.68,not 0.87)
Kinugawa housing
A/R 73 10cm Turbo Turbine Housing ( Fit 56.5mm Trim 84 Wheel)
Here is the my turbo id tag
Edited by R31 POWER
a friend of mine got one for his gt35r and it looks pretty good, he said the exhaust wheel just just touches inside and it needs MINIMAL machining.
still worth buying for the gains you get for going to a small housing imo.
I have modified quite a few of those Kando housings to external gate. They are great housings and flow well.
I even have one on the bench here if you want me to take measurements, or you could make an offer on it. ;)
Just get Stao to machine it out to suit.
Am using one of these housings with a 3076R, and have seen another car using one with the same turbo.
Performance is exactly as expected. Fantastic value for money... Much cheaper way of getting a v-band rear housing than buying garrett.
Sounds promising :D
Reason for asking is im thinking of going 6boost low mount. I really dont want to hack up the rear housing/ beautiful dump haha.
ARTZ, it does have a hairline crack yeah. I noticed it when i got it rebuilt a couple of years ago.
Scotty nm35, which ar housing do you have? I was looking at doing what AngryRB did to his housing!
http://www.skylinesaustralia.com/forums/topic/426934-angryrbs-r33-street-sweeper/page-2
Sounds promising :D
yeah have seen them cracked...its ok until you pull it off and it shifts...
Thats exactly what Scotty did to my kinugawa housing....sits on stock manifold and works well, no need for a 6 boost really as the stock manifold will handle what that turbo can put out.....just tell him you want what artz has ;)
but i dont think the housing he has will fit gt30 as its a t67 housing...maybe it can be milled out not sure...
I think it runs the same housing as yours doesn't it Artz? It was from Stao originally, came on a T67 billet turbo (bigger compressor only I think, I can check with Hypergear) with the .73 rear in T3. It was removed due to needing a T25 flange housing and has never been used.
I can do an external gate off this one and send it up if you like, if it is suitable for machining to match your turbine.
Angryrb had a split pulse manifold and turbo, requiring the wastegate to be split also. I helped him design the split single gate setup off the housing but it was much more complex than Artz housing above. I assume from your housing choice you were looking at a T3 manifold? Artz is correct in saying the stock manifold will flow the numbers...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
