Turbo guru's, do you think this would fit it?
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-Garrett-GT3071R-GT2835-A-R-73-10cm-56-5mm-Trim84/291020897812?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D261%26meid%3D3436767607632936440%26pid%3D100005%26prg%3D1088%26rk%3D2%26rkt%3D5%26sd%3D291034391697%26
Or even this one?
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-Garrett-GT3071R-GT2835-56-5mm-Trim-84-A-R-61-8cm-T3-/291034391697?pt=AU_Car_Parts_Accessories&hash=item43c3006491
As far as i know the HKS gt2835 has these specs
TURBINE:
-Wheel- 84 Trim - 56.5 Major / 51.8 Exducer
-Housing- T3 inlet / Outlet spec:
-0.68 AR (Mine is 0.68,not 0.87)
Kinugawa housing
A/R 73 10cm Turbo Turbine Housing ( Fit 56.5mm Trim 84 Wheel)
Here is the my turbo id tag
Edited by R31 POWER
a friend of mine got one for his gt35r and it looks pretty good, he said the exhaust wheel just just touches inside and it needs MINIMAL machining.
still worth buying for the gains you get for going to a small housing imo.
I have modified quite a few of those Kando housings to external gate. They are great housings and flow well.
I even have one on the bench here if you want me to take measurements, or you could make an offer on it. ;)
Just get Stao to machine it out to suit.
Am using one of these housings with a 3076R, and have seen another car using one with the same turbo.
Performance is exactly as expected. Fantastic value for money... Much cheaper way of getting a v-band rear housing than buying garrett.
Sounds promising :D
Reason for asking is im thinking of going 6boost low mount. I really dont want to hack up the rear housing/ beautiful dump haha.
ARTZ, it does have a hairline crack yeah. I noticed it when i got it rebuilt a couple of years ago.
Scotty nm35, which ar housing do you have? I was looking at doing what AngryRB did to his housing!
http://www.skylinesaustralia.com/forums/topic/426934-angryrbs-r33-street-sweeper/page-2
Sounds promising :D
yeah have seen them cracked...its ok until you pull it off and it shifts...
Thats exactly what Scotty did to my kinugawa housing....sits on stock manifold and works well, no need for a 6 boost really as the stock manifold will handle what that turbo can put out.....just tell him you want what artz has ;)
but i dont think the housing he has will fit gt30 as its a t67 housing...maybe it can be milled out not sure...
I think it runs the same housing as yours doesn't it Artz? It was from Stao originally, came on a T67 billet turbo (bigger compressor only I think, I can check with Hypergear) with the .73 rear in T3. It was removed due to needing a T25 flange housing and has never been used.
I can do an external gate off this one and send it up if you like, if it is suitable for machining to match your turbine.
Angryrb had a split pulse manifold and turbo, requiring the wastegate to be split also. I helped him design the split single gate setup off the housing but it was much more complex than Artz housing above. I assume from your housing choice you were looking at a T3 manifold? Artz is correct in saying the stock manifold will flow the numbers...
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I elongate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for?   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
