What time approx will the day finish as I have to fly back to work that evening?
Is it to late to enter or have all places been filled ?
Can I bring the misses and a m8 or do they pay entry fees as well?
Finish around 5ish although you are welcome to leave earlier if need be.
Spectators don't need to pay. Spaces still available.
I have completed the application, awaiting reply along with my friend James . Looking forward to attending.
Email sent mate.
Sorry to anyone who hasn't received a message. I'm not getting notifications on my phone any more... :/ Where's our resident IT guy?
Ok guys just thought I would post up a check list of stuff you should inspect and if need be fix on your car before hitting the track.
Check all fluid levels, engine oil, gearbox oil, diff oil, radiator coolant, power steering fluid. Top up or change if it is due and make sure there are no leaks.
Check tyre pressure and inflate if necessary.
Make sure everything in your car is secured down and can’t come loose ie battery, speakers, sub box. Items that are loose in your car remove them at the race track, stuff like the spare tyre, tools. Less weight in the car means faster times.
Helmets – must comply with, or exceed, the standards AS1698, make sure it is in good condition as this is the only thing protecting your head.
AASA licence – You can either buy a day licence for $20 or a year one for $55, if you are going to 3 or more sprint events at either Queensland raceway or Lakeside park in the next 12 months it makes sense to the year licence.
The forms for the licence can be downloaded here http://qldraceways.com.au/files/00-5B0-5%20QR%20Licence%20Application%20ver2.pdf It would save you time to print and fill out the licence form before arriving at Queensland raceway.
Bring some zip ties lol. You will need these to attach your timing chip to your car.
The most important thing is go out there and have fun
  • Like 1
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
