Currently making 249kw/400nm @ 26psi on 98, 300+kw capable turbo with an injector change and an eflex/e85 tune, torque has been limited to 400nm to keep it reliable.
Selling as i am upgrading to a newer model, below are the modifications that have been done to the car, while it has had a few done to it the car is not so heavily/obviously modified or massively lowered to give major issues with a rego inspection. AYC pump has recently been rebuilt ($600) after failing due to corrosion (common issue as they sit under the car exposed) and AYC fluid flushed/replaced when reinstalled.
Performance Mods:
Tomei Poncams
Tomei Adjustable Cam Gears
Mishimoto Aluminium Radiator with single 12" thermofan
MAP EF3 Highflow Evo 9 turbo (looks stock externally)
Turbosmart 1.7bar wastegate actuator
Stock evo 8 Exhaust Manifold (EGR has been removed)
Greddy Front Mount Intercooler and piping
Brand new Evo 9 MR metal blow off valve (older model ones leak with higher boost)
Odysee Dry Cell battery
Sard 700cc Fuel injectors
Tomei Fuel Rail
Turbosmart 800 Fuel Pressure Regulator
Walbro 255LPH Fuel Pump
Full 3" Stainless turbo back exhaust (Invidia 3" Dump and front pipe, 3" cat, 3" trust cat back, also includes rego/neighbour friendly (90db @ 3500) 3" diff back muffler)
Coil on plug Direct Fire Ignition Packs
Excedy Hyper Metal Racing Clutch
Goodridge braided brake lines
Remaped standard ECU (tuned by Benchmark Evolution Solutions)
Apexi AVCR Boost Controller (connected but running base wastegate pressure, only required if you wish to retune the car on E85/e-flex with more than 26psi)
Greddy FATTDC Turbo Timer
WBo2 2J9 Wideband o2 sensor + 52mm gauge (model: LA1) (also connected to the ECU (Rear O2 input) for data logging/tuning purposes, sensor is 6 months old)
JMF 3" alloy intake pipe
K&N 4.5" pod filter
Cusco front strut brace
Entertainment:
Alpine Double din 7" DVD player/Touch screen entertainment system
Alpine Typer R Splits in the front
Alpine Type R 5" in the rear
Alpine Roof mounted TV
Alpine PDX - 4.100 (4x100w Amp)
Powered 8" sub mounted under drivers seat
Can also inculde a boot setup that came with the car when i got it (2x Alpine type R 12" subs in a box, false floors covering the entire boot floor (carpeted) and an Alpine PDX 1.1000 amp, some wiring will be required to reinstall)
Aesthetic Mods:
18" +520 5zigen Racing Rims
Eibach Progressive rate lowered springs (25mm all round)
Near new Bilstein shocks (6 months old)
Cusco Front Strut Brace
Rear windows tinted, fronts untinted (front tint was removed for rego purposes)
Interior dash trim piece painted to match exterior colour
Brakes painted Orange
Price: $21000 ONO
Contact: 0419302418
Pics:
post-32350-0-97655500-1387262889_thumb.jpg post-32350-0-96059500-1387262895_thumb.jpg post-32350-0-34573200-1387262900_thumb.jpg post-32350-0-76743600-1387262906_thumb.jpg post-32350-0-74113300-1387262911_thumb.jpg post-32350-0-27486600-1387262917_thumb.jpg post-32350-0-81097900-1387262924_thumb.jpg post-32350-0-09973700-1387262930_thumb.jpg post-32350-0-53445700-1387262935_thumb.jpg
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
  • 4 weeks later...
