yes that hose should go into the pipe the MAF is on. it is the cam cover breather hose.
that ticking noise could well be the common R33 timing belt cover resonance sound. very common to get it and for it then to disappear when the cover is off. nonetheless, it would be worth making sure it isn't the cam belt or any other belt rubbing on something or a bearing on its way out.
Finally, it doesn't sound like your BOV is working correctly as it shouldn't be building pressure and dosing that easily from my recollection. stock turbo and stock BOV?
from here you need to plug in with a consult and computer and make sure that the ECU is seeing correct temps (75-80deg when warm) and correct airflow figures as well as you are sure you don't have any boost leaks. often a leak between the turbo and the manifold will cause excessive rich running as its losing air from the system so their is too much fuel for the air that the engine ends up with... = black smoke and running rich.
Edited by jjman
Yes stock turbo and hks type bov like chinese copy or something.. but now everything works , the noise came because i didn't have gasket between CAS and the cover now the noise is gone, but i failed Emission test on idle..
Emissions IDLE
HC - 140
CO % - 1,7
02 % - 6,1
CO2 % - 8,8
Lambda - empty space
Emissions >2000rpm
HC - 58
CO % - 0,2
O2 % - 1,4
CO2 % - 14,4
Lambda 1,03
any ideas?
id say look at the AFM (do a search on faulty afm's)- though off the top of my head I cant remember if the AFM has an influence at idle.
Otherwise, you might find that you have put the CAS back on out of alignment and so the timing is retarded and not burning the fuel properly.
Also do a search on correct checking of the timing with a light (e.g. from plug 1, not the signal wire which can be a bit incorrect).
afm affects startup and idle. It was the first thing my tuner picked up on when i started the car. a new one will make a world of difference.
and you've done the right things to lean the car out. o2, water temp, thermostat. Now I'd be changing plugs, airfilter, and possibly taking it back to stock boost.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
