Hey guys,
Just putting this expression of interest out there for a long block.
The engine was built by Advan Performance Centre in NSW and was a no expense spared build.
The engine is a 1996 S2 RB25 and was rebuilt with the following specifications:
BLOCK
- R34 GTR N1 crankshaft to bring engine capacity to 2.6L
- H beam Carillo connecting rods
- Mahle forged pistons
- N1 Oil pump
- N1 Water pump
- ACL Pro Series bearings
- New welsh plugs, gaskets etc. done during build
HEAD
- HKS metal headgasket
- HKS 264 degree intake and exhaust camshafts with VCT removed
- HKS Cam gears
- HKS Valve Springs
- HKS Timing Belt
- New seals, guides, valves etc. done during build
- Oil restrictors
- ARP Head Studs
- Machining, porting and polishing all carried out by Advan Performance Centre
This is a big HP engine built to withstand the 700HP and 8000RPM limiter is runs all day long. Engine has now done just under 20,000km and is healthy as ever. Only ever run on Motul Chrono 10W40.
* Currently the car is making between 360-390rwkw on BP98 on 1.5-1.6BAR of boost pressure through a GT3540R in a R33 GTST. The car is an absolute animal when it comes on and is a real handful to keep straight.
The engine is still in the vehicle so can be test driven if required. I'm hoping not to pull the motor out until I have a buyer interested but will see how I go.
Asking $8000 for the long block but I am open to reasonable offers if the price doesn't seem fair.
If some one wanted the complete engine setup with manifolds, turbo etc. I would be open to discuss that as well.
The car has run a low 11 second pass with this package in street trim on a shitty track. Put the engine into a VL or a S chassis and you have a 10 second car.
Any one that has done an engine build like this through a well known workshop knows how much money gets put into these builds and the brand new parts alone are worth more than what I'm asking for the engine so I think it is fair.
If there is any more info I can think of I will update the thread. Just quickly writing it up so I may have missed something!
Thanks guys.
Phil
Will give a free bump as well. Seen this package in its early days after build and it sounded like a f**king mental angry chainsaw on crack! Would be a perfect buy for someone looking to save a few dollars
Edited by Weapon
Engine is two years old and has done approx 18,000km. Didn't keep any receipts unfortunately.
I'm planning on dropping the sump off and taking photos of the crank, rods and pistons though to show proof of the internals.
If some one just wanted the bottom end I will seperate if need be.
Won't seperate the head until I have a buyer for the bottom end though as the head/cams will be quite easy to sell.
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
